Fuel Additive
Old Dec 1, 2022 | 08:21 AM
hillduty's Avatar
hillduty
Fuel Additive
What is everybody using for a fuel additive for 6.7 Powerstroke?
I have used Stanadyne on other diesels for years.
Popular Reply
Dec 1, 2022, 09:15 PM
seijirou's Avatar
seijirou
Originally Posted by acadianbob
Why do you need any additive?
Well since you asked.
See Bosch's report on diesel fuel lubricity here. Why do we care what Bosch thinks? They manufacture our CP4 high pressure fuel pump that Ford uses. The lubricity measurement is done using a standard HFRR test that in simple terms intentionally creates friction between a ball bearing and a plate in a controlled fashion with diesel fuel as a lubricant, and then measures the resulting wear scar. For rated service life of Bosch high pressure fuel pumps they prescribe a maximum wear scar of 460 micrometers.
Fuel manufacturers use the exact same test as one of the benchmarks for target performance when they formulate their fuels. However US manufacturers target a test result of 520 micrometers, which is a result that Bosch has concluded is not good enough. As a result you can expect the service life bell curve of all Bosch's high pressure fuel pumps in the US to shift shorter, resulting in more premature failures. This study was done back in 2003 and predicted what we see today across all of the big 3, a too-common premature failure of CP4 HPFPs.
Ford will never ever admit that they know the pumps they're using with the fuels we have available are a combination more likely to fail prematurely. Even offering lubricity additives would effectively be admission. That would be begging for a very expensive class action lawsuit. Feigning ignorance gives room for benefit of the doubt which in the grand scheme is less damaging to pocketbooks and reputation than the uptick in the number of people who will have problems. Presumably they've determined that the cost benefit of going with something else isn't favorable, they're sticking with the CP4 for now.
So you have some choices. Just go with what Ford says, and by the averages you'll still probably be fine. There have been some bad stories about Ford unreasonably denying CP4 failure warranties on some very questionable basis' like "the tech smelled something" and disregarding actual lab analysis of the fuel that showed it was only diesel, calling the person's bluff about going to court over it. But like anything else it's the bad stories that you hear about and there could be 1,000 honored warranties to every bad story.
Or you can decide that on this one you're not going to trust Ford and take your own actions to mitigate the risk. For my part, while I still like Ford a lot, this is an area where I believe they're willingly transferring the risk to owners so I don't really trust them to do us right on the warranty side, when they're doing us dirty on the equipment side. I use additives that add lubricity and have shown to bring the same fuel that tests in the 520-530 micron range down to the 350-400 range. This puts them well within spec for normal service life. In addition I'm spending some extra to put a diaper on the CP4 so if it defecates the cradle so to speak, the problem is contained at the pump and doesn't destroy $10,000 worth of equipment downstream. And that's really the kicker. Risk is measured by multiplying likelihood with impact. Even with low likelihood a high enough impact still comes out to a risk value high enough to act on. If cost of the might-happen failure weren't so high then I wouldn't willingly put myself out of the terms of the warranty. I don't usually bother with this kind of stuff, but this one is big enough that my own risk acceptance threshold is crossed. A different but similar comparison is buying lottery tickets, I don't ever buy them except every now and then the lump-sum minus tax payout divided by the odds ends up where every chance to play is worth more $ than the cost of the chance. Cross that threshold and I get involved.
Old Dec 1, 2022 | 08:25 AM
westracing01's Avatar
westracing01
There must be a zillion threads on here, but I'll bite.
Optilube XPD every fill up.
Old Dec 1, 2022 | 08:49 AM
riverratrusty's Avatar
riverratrusty
I say it depends on what you are after. My primary concern is keeping the CP4 pump lubed. Opt-Lube XL every tank for me. Small dosing and minimal price per gallon treated. I switch to the XDP Dec-Feb as some of the places I camp are below freezing at night.
As a previous reply stated there are tons of threads about this and they can get our of control like an oil thread pretty quick.
Old Dec 1, 2022 | 08:52 AM
acdii's Avatar
acdii
Hot Shots Secret. Only takes an ounce to a 50 gallon tank.
Old Dec 1, 2022 | 08:55 AM
Dsmoto32's Avatar
Dsmoto32
Anyone using Archoil?
Old Dec 1, 2022 | 09:48 AM
ToMang07's Avatar
ToMang07
Pretty sure it's an ounce 20/gal?
Old Dec 1, 2022 | 09:53 AM
donovan's Avatar
donovan
Stanadyne for the last 3 diesel trucks. No problems with the cp4 or emissions.
Old Dec 1, 2022 | 10:31 AM
Ford Fx4's Avatar
Ford Fx4
PM-22
I get gallon jugs of it on rockauto for around 31.00.
It's 1oz per 7.75 gallons of fuel.
Old Dec 1, 2022 | 11:17 AM
Pugga's Avatar
Pugga
Depends on which additive. The EDT I believe is an ounce per 25 gallons, the winter additive is an ounce per 5 gallons, their other products vary.
I run Hot Shots EDT and their winter additive when the temps drop.
Old Dec 1, 2022 | 11:31 AM
ford4wd08's Avatar
ford4wd08
Originally Posted by Ford Fx4
PM-22
Dang I wish I would have thought to look on Rockauto before ordering it from summit....
Old Dec 1, 2022 | 01:10 PM
acdii's Avatar
acdii
25, but I only fill when it reaches half tank, so one ounce per fill for me. I add 2 ounces every 4th tank.
Old Dec 1, 2022 | 02:15 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Hot Shots EDT in the warmer weather and Hot Shots Winter Blend in the colder months. In addition to the HS, I also use Better Diesel FBC.
Old Dec 1, 2022 | 03:12 PM
1960_F100's Avatar
1960_F100
I've been wondering about this too...second diesel I've owned, first PS. I believe Ford does not recommend any additives? What happens to our warranty?
Old Dec 1, 2022 | 03:37 PM
High_HP's Avatar
High_HP
The Safety Data Sheets will tell you a lot after studying them. I avoid Opti Lube and Hot Shots after studying them. One of them simply uses bio soy for lube.
Stanadyne Summer formula looks real good, so does Motorcraft pm22 for lube properties. Stanadyne parent company designs fuel systems which helps.​​​​​​​
Old Dec 1, 2022 | 03:44 PM
1960_F100's Avatar
1960_F100
Interesting, so you could just use biodiesel instead! I think my buddy in SD uses Stanadyne in all his diesels. I was just concerned with voiding the warranty.
