Fuel Additive
Old Dec 2, 2022 | 11:31 AM
  #31
speakerfritz's Avatar
speakerfritz
Originally Posted by ToMang07
When the #1 thing that takes out a CP4 is water.... y'all really rolling the dice with biodiesel. Good luck with that.
according to ford anyway.
they can’t explain how the water makes it to the cp4 since there is both a water separator on ford trucks as well as “water in fuel” warning codes.
Old Dec 2, 2022 | 11:38 AM
  #32
Roach's Avatar
Roach
Originally Posted by westracing01
There must be a zillion threads on here, but I'll bite.
Optilube XPD every fill up.
I second that.
Old Dec 2, 2022 | 01:35 PM
  #33
redford's Avatar
redford
FTE Leadership Emeritus
Project Farm did an interesting comparison study of popular diesel fuel additives. Lubricity, anti-gel properties and anti-corrosion properties were tested.
Old Dec 2, 2022 | 02:02 PM
  #34
H4Racing's Avatar
H4Racing
Originally Posted by seijirou
Well since you asked.
See Bosch's report on diesel fuel lubricity here. Why do we care what Bosch thinks? They manufacture our CP4 high pressure fuel pump that Ford uses. The lubricity measurement is done using a standard HFRR test that in simple terms intentionally creates friction between a ball bearing and a plate in a controlled fashion with diesel fuel as a lubricant, and then measures the resulting wear scar. For rated service life of Bosch high pressure fuel pumps they prescribe a maximum wear scar of 460 micrometers.
This is why I use OptiLube XL every fill up.
I've used Archoil 6400D when I do an oil change (if I can get it for $10 or less).....it's supposed to clean up the injectors and stuff, but I haven't noticed a difference. Also got a free bottle of 6500D cetane booster and have been running it for the past few tanks. Again, haven't really noticed a difference.
Old Dec 2, 2022 | 06:00 PM
  #35
IADiver's Avatar
IADiver
I stand corrected, looks like Hot Shot Secret may be worth it.
  #36
bernie165's Avatar
bernie165
Originally Posted by acdii
Trust, but Verify.
Trust that the fuel you are getting every day has good Lubricity, and Anti-gel(for us salt belters), but verify by using a good additive. When Diesel is $5 a gallon, whats another $1.38? Thats what a 2 ounce shot costs of Hot Shots EDT. Thats every 3rd tank for me, two tanks is one shot, or $.69 since I fill at the half mark.
Cheap insurance.
Took words out of my mouth
Fuel quality varies along with fuel cleanliness
Stanadyne Performance Formula every tank
Old Dec 2, 2022 | 10:42 PM
  #37
4wd6.7L's Avatar
4wd6.7L
Originally Posted by speakerfritz
that would be a good thing . which one uses bio soy and how can we verify.
advantage of bio soy is no heavy metals so your o2 and nox sensros wont get contaminated.
Could be the Opti-Lube. Opti-Lube XL shows 40% Soy methyl ester, Summer Lube+ 30% Soy methyl ester.
Old Dec 2, 2022 | 10:54 PM
  #38
speakerfritz
that would be great.
I just found a fuel supplier that will sell me 5 gallon cans of b99 . 2 cans of that will put me at b20.
Old Dec 3, 2022 | 12:26 AM
  #39
Vics2024Platinum's Avatar
Vics2024Platinum
Originally Posted by riverratrusty
I say it depends on what you are after. My primary concern is keeping the CP4 pump lubed. Opt-Lube XL every tank for me. Small dosing and minimal price per gallon treated. I switch to the XDP Dec-Feb as some of the places I camp are below freezing at night.
As a previous reply stated there are tons of threads about this and they can get our of control like an oil thread pretty quick.
Me too I use Opti-lube at every fill up and power service diesel clean in the summer and the diesel fuel supplement in the winter to increase the cetane of the very poor 40 cetane fuel and also the fuel supplement is an anti-gel.The power service is endorsed by Cummins in their engines.
Old Dec 3, 2022 | 05:01 PM
  #40
acdii's Avatar
acdii
https://youtu.be/n8gDN_6esfs
This is what led me to use the Hot Shots. It performed the best out of all his tests. While no where NEAR scientific, it is pretty much real world testing that he did. HSS proved the best for anti gel and lubricity, which are the two main reasons I use it in all my diesels. Been using additives in my 2002 Kubota since day one and it starts and run great every time I turn the key.
Old Dec 3, 2022 | 05:16 PM
  #41
seijirou's Avatar
seijirou
Same. His tests may not be perfectly laboratory controlled tests and I can think of ways to improve them, but they're good enough that I think going further would just be unnecessary diminishing returns.
I also have no delusions that because I use some product that means I won't have a problem, life doesn't work that way. Across all the pumps out there, their life will be a normal distribution in a bell curve. All we can accomplish by using a better fuel, or an additive, or anything else is to slide that bell curve in our favor, but there will always be outliers in the distribution. There will be some pump that will go 500k miles with the worst fuel in the world, and some pump that dies in 5k miles with the best fuel in the world. We also basically only hear about situations that fall out on the edges of the curve; the exceptions be them good or bad but by human nature we tend to only report on the bad ones. That's why anecdotes are dangerous.
I don't want to scare anybody into thinking you need an additive or else, or that any additive comes with guarantees.
Old Dec 3, 2022 | 05:51 PM
  #42
JS450KR's Avatar
JS450KR
Just joined FTE a few days ago, over 50yrs. experience as a diesel mechanic/tech ,saw quite a evolution in the diesel industry and also fuels, went from regular #2 fuel to diesel to low sulfur to ultra low sulfur.Without getting into a major p*****g contest, I can attest ultra low sulfur does lack lubricating qualities and any conditioner that helps lubricate is better than nothing.
Old Dec 3, 2022 | 06:44 PM
  #43
Svenster's Avatar
Svenster
I have been using Power Serve products since 2008 in my F250 6.4 PSD based on recommendations from friends that ran diesel trucks at the time. Though I never had any issues with the 6.4 nor the Power Serve products, that Project Farm video is pretty persuasive. I'll be trying the Hot Shots EDT and their Winter Anti-Gel in my new 2022 6.7 PSD.
Old Dec 3, 2022 | 08:44 PM
  #44
tacticalturnip's Avatar
tacticalturnip
Should I be concerned about this with regards to my tractor?
Old Dec 4, 2022 | 03:51 AM
  #45
RA122522's Avatar
RA122522
Lucas and drain water separator monthly
