Quick and easy solar install
Old Nov 19, 2022 | 11:50 AM
oresto's Avatar
oresto
Trailering
Two solar panels installed. Front panel is 20w for my starter battery. There is VSR to regulate and charge the rear battery via the alternator as well. The back is a 50w panel to trickle charge my aux battery on the 3000w inverter. Easiest mount. Just use stainless steel tie wrap amd mount to the roof rack. mounted a voltage meter on the battery box.
Old Nov 19, 2022 | 04:21 PM
01__Excursion's Avatar
01__Excursion
Can't tell, hopefully you didn't use plastic zip ties. Stainless ones area avail.
Amazon Amazon
Old Nov 20, 2022 | 07:37 AM
bajaphile's Avatar
bajaphile
Doesn't the VSR just open once it senses a charging source from either side? That would also require 2 separate charge controllers. I'd just use one large panel wired in to my starter battery with the VSR wired to the auxiliary so that the auxiliary battery charges when the truck is running or from a solid solar charge input. Either way, I guess that works as is!
Old Nov 20, 2022 | 08:26 AM
magicschoolbus's Avatar
magicschoolbus
I guess we all "think" about doing these things, but never do it. Curious, what problem are you solving or what more importantly, what new functionality are you adding? What could you plug in operate, and how long?
Old Nov 21, 2022 | 10:47 AM
kostkafex's Avatar
kostkafex
interested to see how you came through the roof, have any pics of that part?
Old Nov 21, 2022 | 11:17 AM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
I have actually had a 25 watt panel on mine for some time, also mounted on the roof rack, but my roof rack is much larger.
I am thinking about upgrading it to a 100 watt though as i am about to add a second battery, and i plan to add more gear in the truck including a mobile starlink setup, the new one that you can use while in motion.
oresto
Jul 8, 2023 07:30 PM
drlugomelendez
Electrical Systems/Wiring
Jul 8, 2021 07:18 PM
norman2012
15
Mar 23, 2021 10:58 PM
82_F100_300Six
Apr 27, 2018 07:58 PM
Blue7.3
Australia Chapter
Sep 7, 2014 11:05 PM
