Auto dim headlights?
Old Nov 16, 2022 | 08:21 PM
kd5zll's Avatar
kd5zll
Has anyone wired up a sensor to put auto dim function on one of our trucks? I can find wiring plans, etc. But they are not quite as simple to follow as my brain needs. I know it requires a light sensor, and at least 1 relay. While im waiting on my new headlight housings to arrive... i kinda slid into this rabbit hole.... my upgrade syndrome is firing a bit heavy. In my mind at least, auto dim, if functional is never a bad thing. Helps me not be a jackass to oncoming traffic, anyway..
Old Nov 16, 2022 | 10:25 PM
TroyH.'s Avatar
TroyH.
1st Gear
This was one of my favorite features on my Ram 1500. Makes long night drives a lot nicer.
If you figure out a way to make this happen, I'll send you a bottle of whiskey.
Old Nov 16, 2022 | 11:42 PM
kd5zll's Avatar
kd5zll
Besides cameras, auto dim headlights are the only, imo, important/practical thing these trucks are missing. Otherwise, you can get basically all the other common bells and whistles in a nice head unit.
im going to try and get something figured out. For both myself. And every vehicle facing me at night.
Old Nov 17, 2022 | 09:04 AM
F250_'s Avatar
F250_
Awesome effort. I concur with the advantage, and will watch this thread closely.
Perhaps it may work to get a wiring diagram from a vehicle which has the feature to identify all components required for the upgrade, and then compare that diagram with one of ours to identify connection points and real-world feasibility.
Were I electronically inclined, this is something I would try to do, but that just isn't in my wheelhouse. I've thought about this very upgrade over the years, ever since driving a 2014 XC60 which had the auto-dimming feature on a long winter evening drive in the UP.
Old Nov 18, 2022 | 02:10 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Just to be clear, you want high beams to dip in response to oncoming lights? Not headlights on at night and off when daylight?
Old Nov 18, 2022 | 07:48 AM
Kwikkordead's Avatar
Kwikkordead
High/Low beams, at least on my 99.5 are mechanically controlled. I can think of no easy way to get a modification like this accomplished without converting it over to a black box control of some kind.
Old Nov 18, 2022 | 08:13 AM
Tpayne621's Avatar
Tpayne621
Photosensor of some sorts on windshield to trigger relays hard wired to headlights. Bypass the multifunction switch. Could be done fairly easy if you could find a sensor to work.
Old Nov 18, 2022 | 08:25 AM
F250_'s Avatar
F250_
The next step would then be a toggle switch on the sensor setup so that the system could be set to operate purely as OEM or as the upgraded "smart" control.
Old Nov 18, 2022 | 10:13 AM
kd5zll's Avatar
kd5zll
correct. Not trying to redo the entire system, just make the high beams dip to lows, with oncoming headlights.
this
Old Nov 18, 2022 | 10:22 AM
Tpayne621's Avatar
Tpayne621
See if you can find a sensor that might work and I'll help trying it out wiring it up.
Old Nov 18, 2022 | 03:42 PM
aawlberninf350
It's a Van Gogh
Here's a writeup on the 60's Tbird set up, might have some clues for you. Similar options on Lincolns and Cadillacs back to the 50's.
Old Nov 18, 2022 | 05:38 PM
kd5zll's Avatar
kd5zll
Simplest form, is to find a cheap enough sensor for an existing vehicle, wire into that device to a relay, that just kicks high beam power to the low beam. Then when the sensor releases after losing light input, the relay lets power back to high beams. My wifes rogue has a very sensitive sensor, cost 150 bucks. They werent sure how much the module would cost, but im, mostly, certain that no module would be needed. That sensor does a lot for a new car, but we wouldnt even want the headache of all that automation. Im going to casually continue searching for either a more affordable, existing sensor, or a clean diy kit for a sensor.
Old Nov 19, 2022 | 07:31 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Just do unto others as they do unto you.....leave the high beams, LED "fog lights" in the bumper, LED bar in front of the grille, and square LED lights mounted at the lower corners of the windshield on all the time.
THEN hit 'em with the 10,000,000 candlepower spotlight aimed right at the steering wheel as they approach.
Dimmer switches? We don't need no stinkin' dimmer switches.
My demeanor hints to the fact it's hunting season and the highway is inundated with Underarmor-clad out-of-staters who don't GAF. Usually the lighting is accompanyied by 35" tires on 24" wheels sticking 10" outside the fenders and a 8" octagon-shaped exhaust tip.....oh, and wheel arch openings that have been clearanced 6" by only two seasons' worth of road salt in Minnesota.
Just to help you in your endeavor, look for an inside rearview mirror from a vehicle with the electrochromatic (auto darkening) feature. Lots of vehicles had those back in the early 2000s. They employ photoelectric cells that point forward as well as rearward.
Old Nov 19, 2022 | 07:43 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
This has gotten really bad over the past few years, much worse than before. This past Thursday evening we were bringing home a couple slabs of poplar wood from a lumber mill about 1.5 hours from the house. The return trip was during dark hours due to daylight savings time shift.
All of the traveling was on back roads in the country where high beams are suitable and should be used.
I would say 40% of the oncoming traffic did not dim their brights as we approached each other. 50% of those people managed to "remember" to dim their lights as I started flashing them. About 20% had ridiculously pointed LED bulbs and a couple had light bars that were insane to be driving towards.
We try not to drive at night much due to the wildlife and people that don't know how to use their high beam switch.
As for the auto dimming lights being retrofitted to a 7.3L era truck, I commend you for your efforts and ingenuity. I may be able to provide wiring diagrams or schematics if needed and would be glad to help.
Old Nov 19, 2022 | 08:13 AM
Kwikkordead
Mount this thing up, LOL.
https://www.thegreenhead.com/2007/07...-spotlight.php
