2002 F350 Trailer Light Issues
Old Nov 15, 2022 | 06:14 PM
NotoriousPIG's Avatar
NotoriousPIG
02 F350 7.3 CCLB ZF6 Swap
I need to haul a trailer tomorrow and I hooked up to the trailer to verify everything works and I have zero power going to the trailer. No running lights/turn/brakes, nada. I checked the trailer with a different rig and the trailer worked perfectly. So the problem is with my truck.
I replaced fuse #6 that was blown with a new 20A fuse. Still doesn’t light up anything. I checked fuse #38 and it is in good condition. All lights on truck work as they should.
where do I need to go next? I have heard people mention the relay boxes that are near the master cylinder under the hood, but I don’t know what each of these relays do. Is one of them for the trailer lighting perhaps? Here’s a picture of the two relay boxes I have.
any help would be appreciated thanks.
Old Nov 15, 2022 | 08:13 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
The 02 is a bit different than the 01 when it comes to the electrical system the I know, so just a few thoughts.
I am not sure if you have a fuse block under the hood but that is where I would start. Pull out the manual for your truck and read each fuse and location and verify they are good. Like I mentioned, the 01 has the trailer package under the hood, your location may vary.
If the fuses check good look at the relay blocks next. Again the book will tell you what is what.
If nothing else you got a bump on the list.
Old Nov 15, 2022 | 10:17 PM
Kintla's Avatar
Kintla
If nothing works, no running lights, blinkers, brakes I'd be looking at the 7 pin harness first. They get a lot of abuse back there.
Test for power going into the harness, if you have power going into it but nothing at the 7 pin connector you've found your problem.
Old Nov 16, 2022 | 06:11 AM
FordTruckNoob's Avatar
FordTruckNoob
Check that you have a good ground especially.
Old Nov 16, 2022 | 06:09 PM
NotoriousPIG
I pulled the grey 12-pin harness plug (8 small 4x2 pins and 4 larger ones on the outside) that is located behind the spare tire and used a multimeter and a test light on each of the pins and nothing was getting power.
any suggestions on where I should head next?
Old Nov 16, 2022 | 08:15 PM
kd5zll's Avatar
kd5zll
If all your truck lights are working correctly, and none of the trailer wiring has power, while the lights are on... then you need to trace up, from those connectors. Because, at least some of those wires, should share a common feed with the truck lights.
Old Nov 16, 2022 | 09:15 PM
Kintla's Avatar
Kintla
In checking for power at the pigtail connector did you use the ground in the harness or ground to vehicle? Do both to see if results change and if they do you'd know your ground is bad.
Old Nov 16, 2022 | 09:28 PM
NotoriousPIG
I did ground to the vehicle and got no results.
I went “upstream” of the rear 12 pin plug to the next plug which is located right behind the transmission. There’s a 12pin plug here where the truck light wires and the trailer light wires come together into one harness. I tested the plug at this point and got the following results:
Key Off, Lights Off - 1 pin lit up.
Key On, Lights Off - 3 pins lit up
Key On, Lights On - 6 pins lit up.
Flashers On - no pins were flashing
Brakes Applied - no additional pins lit up
so this leads me to believe that I don’t have brake light power up to this point and that I don’t have either blinker power at this point. Signs would point towards one of the 2 smaller relays that are in that small block by the master cylinder? I believe both of these relays are in good shape as they click and sound normal as you would expect.
Hmmm… thoughts?
Old Nov 17, 2022 | 04:38 AM
FordTruckNoob
These wire diagrams should help isolate your issue. The connector "upstream" of the 12-pin appears to be C410 per diagram 95-2 below.
2002 trailer wiring 1
2002 trailer wiring 2
2002 trailer wiring 3
2002 trailer wiring 4
Old Nov 18, 2022 | 01:58 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I'd swap the underhood relays. I think they are the same. Include under dash relays in the rotation if they are the same. Idea is to work the connections in case they are dirty. Hit the sockets with a can of contact cleaner, let dry completely before putting relays back in.
gbkeith
Apr 16, 2018 08:57 PM
Donebrokeit
May 28, 2017 11:49 PM
200454FX4
2004 - 2008 F150
Feb 20, 2009 12:38 PM
jl5086
Jan 7, 2006 08:09 PM
wat704
1997 - 2003 F150
Feb 28, 2005 10:57 PM
