E-150 Wont's Start Up
Old Nov 14, 2022 | 04:08 PM
GoldenOldie99's Avatar
GoldenOldie99
2nd Gear
Question E-150 Wont's Start Up
Hey Guys and Gals,
Complete Econoline newbie here looking for some help. I have a '99 E-150 with 103,000 miles that won't start up.
Code reader pulled P0401 (insufficient EGR flow) and P0455 (EVAP Control System leak) codes. After researching as much as I could and then some, I replaced the DPFE Sensor, it's two hoses, EGR Valve, as well as the Vapor Canister Purge Valve. While replacing these parts I pulled the upper intake manifold and cleaned it up, making sure to cover up the lower manifold while doing so. I drained the coolant, but did not relieve fuel pressure.
Put everything back together the way I found it and now this is happening:
Any ideas?
Old Nov 14, 2022 | 07:45 PM
tabijan's Avatar
tabijan
What engine?
Video sounds to me like a fuel problem. I’d start by checking rail pressure.
Sixto
07 E350 5.4 189K miles
Old Nov 15, 2022 | 07:47 AM
GoldenOldie99
2nd Gear
Hi tabijan,
. It's a 4.2L V6, and it was starting up and idling just fine before I replaced those parts.
I checked the fuel inertia switch which didn't need to be reset, and I pulled two spark plugs, the driver side plug was dry and the passenger side plug was wet.
Old Nov 15, 2022 | 07:57 AM
tabijan's Avatar
tabijan
Could you have misconnected injector or sensor wires? If electronic, is the throttle actuator hooked up? I don’t know if it’s safe to do so but can you tip the throttle plate to make sure air’s getting to the cylinders?
Sixto
calansvc
3.8 & 4.2L V6
May 11, 2019 02:08 AM
IHateCommieCars
Nov 11, 2016 03:36 PM
servitium
Apr 10, 2011 02:31 PM
jpcnorthwood
Feb 5, 2011 06:23 PM
Bronco76Ranger00
1983 - 2012 Ranger & B-Series
Nov 11, 2009 08:51 PM
