Hi idle---still
Old Jul 22, 1999 | 07:18 AM
island's Avatar
island
Hi idle---still
My 1990 F150 5L is still idling high after cleaning the throttle bores and changing the idle by pass valve. Cleaning it never helped.
My question is this- has anyone ever had a high idle due to a gasket leak in the upper intake manifold? I could find no fault codes in the computer
Old Jul 22, 1999 | 10:44 AM
car 36
Guest
Posts: n/a
Hi idle---still
Do some serious vacuum leak checking. Also, make sure the "butterflys" in the throttle body are closing all of the way, and that there's no carbon buildup causing them to not fully close.
Old Jul 23, 1999 | 05:52 AM
Deen Hylton
Guest
Posts: n/a
Hi idle---still
According to "Ford Fuel Injection and Electronic Engine Control" by Charles Probst, improper idle speed can also be caused by: Engine too cool or too hot, A/C input, throttle sticking, linkage binding, and Speed Control linkage. The book also goes on to say that the Oxygen Sensor can be faulty or the ignition timing be off. Good luck. P.S. It also talks about vacuum leaks, contaminated throttle bores, etc. but others have already addressed that.
Old Jul 23, 1999 | 01:29 PM
jmerritt's Avatar
jmerritt
Hi idle---still
Had the same problem with my '90 Continental. Turned out to be the Throttle Position Sensor connection was corroded. Removed the connection and put some dielctric grease on the pins and pushed the connector off and on a few times to clean it up. Solved the problem. Did I underatand you did a propane check and the idle speed increased or decreased? Increased means you definitely have a vacuum leak below the Throttle Body. Decreased means no vacuum leak. However, you could have both a vacuum leak and the bad TPS without setting a code.
Regards
John
Old Jul 24, 1999 | 09:33 PM
Chris Custer
Guest
Posts: n/a
Hi idle---still
amdriven2liv
Nov 8, 2018 02:21 AM
Johnmd
28
Jan 16, 2017 12:44 AM
Diesel_Brad
1983 - 2012 Ranger & B-Series
28
Jan 24, 2016 07:52 AM
Jmoen7
Aug 25, 2015 09:47 PM
Gerryatrics
1997 - 2003 F150
19
Mar 30, 2014 06:11 PM
