Leaf Spring Bushings
Old Nov 13, 2022 | 07:20 PM
theworstshadetreemechanic's Avatar
Trying to replace my rear leaf spring bushings, but the outer metal wall is corroded to the inside of the leaf spring. Any tips to remove it?
Old Nov 14, 2022 | 10:06 AM
Edgethis's Avatar
Edgethis
How are you trying to remove them? I'd suggest some wd40 and using a press to push the bushings out. I would avoid using heat/torch as it could alter the properties of the spring metal itself.
Old Nov 17, 2022 | 04:25 AM
hivoltj's Avatar
hivoltj
Air chisel
Old Nov 17, 2022 | 12:40 PM
obsxl's Avatar
obsxl
cut them in half with a sawzall and they should come right out. just don’t cut your leaf springs lol
HGaither
Mar 12, 2022 09:17 AM
milkstake
Apr 20, 2021 08:47 AM
Pickupmanx2
Aug 11, 2014 01:04 AM
95_460
Feb 5, 2011 02:19 PM
mayerst1
Mar 10, 2006 10:26 AM
