Is there a magic leaf spring bushing lube?
Old Mar 11, 2022 | 08:07 PM
HGaither's Avatar
HGaither
After reloading my camper from adding an upper overload leaf I seem to be getting a lot of squeaky bushing noises. They seem to be coming from the rear leaf bushings. I have tried some silicone lube and JB blaster with not much results. Just wondering if anyone else has had this problem and what you did to get rid of it.
Old Mar 11, 2022 | 08:30 PM
HRTKD's Avatar
HRTKD
Sometimes, suspension squeaks can be as simple as dirt between the leaves of the springs. I've used Boeshield T-9 to help with suspension squeaks, but that was related to heim joints, not leaf springs.
If you really think it's the bushing, you could remove the bolt and lube the inside of the bushing. Maybe the bushing is shot?
Old Mar 12, 2022 | 06:51 AM
HGaither's Avatar
HGaither
I did not notice the squeak with the camper off but the truck is set up fairly stiff. It's a 2021 truck so I would hope the bushing is good.
Old Mar 12, 2022 | 09:17 AM
allendks45's Avatar
allendks45
Anyone but me remember the body/cab bushings used to go bad in less than 7 years on these trucks? Energy suspensions (not an affiliate) makes really good bushings I've used on previous cars and trucks (replaced leaf and cab bushings) that work really well. Whatever lube they send with their kits seems durable.
waylen89
Aug 8, 2016 03:45 PM
Byrddog
1983 - 2012 Ranger & B-Series
Jun 6, 2012 07:28 AM
spinella
Mar 3, 2010 08:49 PM
86Broncho2gal
Bronco II
Sep 5, 2001 04:57 PM
