Will Not Crank/Start
Old Nov 12, 2022 | 07:48 PM
oldschooldad21's Avatar
oldschooldad21
1st Gear
I have a 2003 F-350 Super Duty Dually with a 6.0 Diesel. I started the truck and it was running fine (parked). All of a sudden, it accelerated by itself to 1000RPM. I turned off the truck and now it won't crank or start. Everything else works, batteries are good, starter is good. Any ideas on what could be the problem?
Old Nov 13, 2022 | 03:20 PM
xcrsp440's Avatar
xcrsp440
What happens when you use the cable on the passenger fender and connect to the positive battery terminal?
Old Nov 13, 2022 | 03:30 PM
bismic's Avatar
bismic
See if you get fuel filling up the secondary fuel filter bowl when you turn the key on.
Check fuse 22.
Turn the key on and verify that the back-up lights come on.
Old Nov 16, 2022 | 09:15 AM
IHateCommieCars's Avatar
IHateCommieCars
What am I missing? I thought it was common for the engine to up its RPM a minute or so after starting cold, maybe depending on the weather?
Old Nov 16, 2022 | 09:25 AM
bismic's Avatar
bismic
Yeah - its is no-crank that he seems to have now that is his issue.
He is a "no-show" anyway, so no matter.
Jack Miller
6.4L Power Stroke Diesel
Feb 20, 2021 09:19 AM
Tiler Carlton
Oct 18, 2020 03:19 PM
ranchmule
Nov 29, 2017 11:55 AM
lilsally2012.tb
May 26, 2016 08:54 AM
devovino
Nov 16, 2015 04:08 PM
