Send Help!
Old Nov 12, 2022 | 01:06 PM
Bcham's Avatar
Bcham
4wd High
Send Help!
During first 10 minutes of cranking the truck surges, lunges while stopped, idles poorly, has a general loss of power.
After it warms up for 10 minutes the problems totally stops and the truck drives great.
I finally got a code obd1 172-Lean 02 Sensor, but it only throws the code if I’ve been driving for a while and on the interstate. My thought is it is a fuel issue, below are the numbers, both tanks gave very close numbers within 1psi:
Warm Up 10 minutes
KOEO-30
Running-33
with Vac line pulled-40
truck has been running for 10 and warmed up
KOEO-39
Running-40
Truck is a 1997 Fordf250HD 351 Windsor. Does this every time, not intermittently.
Why would there be such a difference in pressure based on truck running for 10 minutes. Any help is appreciated.
Old Nov 12, 2022 | 02:01 PM
sandymane's Avatar
sandymane
Pull your vacuum line off the FPR after turning the key on and off several time to prime the pumps. When you pull the line, if you see or smell fuel your FPR may be at fault.
Old Nov 12, 2022 | 02:38 PM
sandymane's Avatar
sandymane
You can also check fuse number 5 in the box under hood. The 15amp fuse controls the H2O sensor.
Old Nov 12, 2022 | 05:05 PM
Bcham's Avatar
Bcham
4wd High
tried this, no smell and no gas. Will try the fuse.
Old Nov 13, 2022 | 09:52 AM
Prototypemech's Avatar
Prototypemech
Check for vacuum leaks very carefully, especially at the pcv valve, vacuum reservoir, and brake booster connection. I bet you're gunna find a split hose. How is your EGR and smog pump system? You can use a mighty-vac pump to check the operations of the valves and make sure they're not stuck wide open.
Bondsman Chris
17
Apr 6, 2017 06:45 PM
mjunk1
35
Mar 14, 2015 10:28 PM
Beaters
6.4L Power Stroke Diesel
Jul 21, 2013 06:59 PM
fridgeddiesel
Aug 21, 2012 09:06 AM
cgarym7
Mar 9, 2009 02:02 AM
