6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L Fuel Rail Code
Old Jul 16, 2013 | 06:00 PM
Beaters's Avatar
Beaters
6.4L Fuel Rail Code
Hey all,
Having a bit of an intermittent problem with my 2008 F250 with the 6.4. A couple weeks ago it started shaking violently and stuttering while driving. Did it a couple more times in the span of a few minutes, then went away and was perfectly fine for a few days. Has been doing the same thing off and on over the last couple of days. Always seems to be when the truck is warmed up (driving 50+ km or a really hot day). Don't seem to have any problems with the truck when it's cold.
The engine light flashed on briefly today while it was shaking and stuttering. Hooked up the scanner and found code P0194 "Fuel Rail Pressure Sensor A Circuit Intermittent/Erratic". Any ideas as to what is wrong here, and could this be causing the intermittent shaking and stuttering problem while driving?
I'm new to Fords and diesel trucks, so any and all help is much appreciated!
Old Jul 16, 2013 | 06:46 PM
senix's Avatar
senix
sensor on the right hand valve cover..probably bad
Old Jul 16, 2013 | 09:11 PM
tgreening's Avatar
tgreening
Originally Posted by Beaters
Hey all,
A bit of advice. Don't dink around with this. IF you are having HP fuel pump issues, and it dies, you could be looking at some serious serious coin to fix the mess it will make. Been there done that.
Old Jul 16, 2013 | 09:21 PM
auriferous's Avatar
auriferous
Hey all,
yes it sounds like the same behavior i had with mine "loose wire " I was told from the dealership when I brought it back been running fine since then
Old Jul 16, 2013 | 09:25 PM
GHeTTo JOe's Avatar
GHeTTo JOe
<table class="ADVV1-HotlineArchives-Whites" cellpadding="0" cellspacing="0"><tbody>
<tr><td class="ADVV1-HotlineArchives-LeftRuledRows">
</td> <td class="ADVV1-HotlineArchives-RuledRows"> Looks to be common for that code to replace the fuel rail pressure sensor
1. Access connector C1278 on the front right of the passenger valve cover.
2. Backprobe the Green wire going into the connector, valve cover side.
3. This is the fuel rail pressure sensor voltage wire, turn the key on, see if the voltage is erratic. Wiggle the engine harness and verify if the voltage jumps or falls.
4. If the voltage does become erratic, check the engine harness near the radiator for chafing or damage.
</td></tr></tbody></table>
Old Jul 16, 2013 | 10:34 PM
auriferous's Avatar
auriferous
yeah that is for sure my problem happened when i went on a camper trip right after a new HPFP install under warranty from the fomoco so it is something to address.[ the mech. told me it was around 6,ooo$ worth of work] but it fell under emmisions warranty and a washboard dirt road in the desert shook a wire loose on the #2 cylinder after the work and nothing since has gone bad .good luck.
Old Jul 17, 2013 | 05:08 PM
Beaters's Avatar
Beaters
Thanks for the help guys, I am planning on ordering a new rail pressure sensor and getting it installed ASAP. Looks like sensor is only $35-$40, but I'll be out a few hours of my labour I think, looking at what all has to come apart to get access to it. I have parked the truck for now till I get it repaired. Anyone know a parts supplier for the wiring harness from the sensor? Might be a good idea to replace it while I'm in there anyway, and insulate it with something too.
Thanks again!
Old Jul 17, 2013 | 05:30 PM
senix's Avatar
senix
tousley ford is one of the vendors here. I order from them.
Old Jul 17, 2013 | 10:00 PM
GHeTTo JOe's Avatar
GHeTTo JOe
Removal and Installation Fuel Rail Pressure (FRP) Sensor
  1. WARNING: Contact with exposed fuel injector wiring, if energized, may result in electric shock. Use care when working on or around energized fuel injector wiring. Fuel injector wiring supplies high voltage to operate the fuel injectors. Failure to follow this instruction may result in serious personal injury.
    NOTICE: Make sure the ignition switch is in the OFF position prior to working on the electronic engine controls or the vehicle may be damaged.
    Turn the ignition switch to the OFF position.
  1. Remove the RH valve cover. For additional information, refer to Section 303-01C.
  1. Disconnect the Fuel Rail Pressure (FRP) sensor electrical connector.
  1. NOTICE: Fuel injection equipment is manufactured to very precise tolerances and fine clearances. To prevent fuel system damage, it is essential that absolute cleanliness is observed when working with these components. Always install fuel system caps on any open orifices or tubes.
    NOTE: Do not reinstall a used FRPsensor. The FRPsensor is a one-time-use sensor due to the crush washer at the bottom of the sensor.
    Remove and discard the FRPsensor.
    • To install, tighten the new FRPsensor in 2 stages.
      • Stage 1: Tighten to 7 Nm (62 lb-in).
      • Stage 2: Tighten an additional 40 degrees.
  1. To install, reverse the removal procedure.
    • Bleed the high-pressure fuel system. For additional information, refer to Section 310-00.
Old Jul 18, 2013 | 06:30 PM
GSchretter's Avatar
GSchretter
Thank you for the info...
I know now from this statement:
"Remove the RH valve cover"
just too much for me to mess with
Old Jul 18, 2013 | 09:26 PM
cheezit's Avatar
cheezit
you may be better off replacing both the frp and the wet loom. ive been down this road way to many times
Old Jul 18, 2013 | 10:33 PM
GHeTTo JOe's Avatar
GHeTTo JOe
whats the wet loom? is it the FRP sensor connector in senix's picture?
Old Jul 19, 2013 | 05:24 PM
cheezit's Avatar
cheezit
yes it is, the wet loom is the under valve cover harness for that and the injectors on the right bank
Old Jul 21, 2013 | 06:49 PM
Beaters's Avatar
Beaters
So the wet loom is the wiring harness and connector that goes to the FRP sensor and the injectors on the right bank? Had heard I should replace that wiring while I'm in there. Any ideas on where to get one of those wiring harnesses? Have my sensor ordered and should be here within the next couple days.
Old Jul 21, 2013 | 06:59 PM
senix's Avatar
senix
tousely ford. Order it from them or at your local dealer. see my pic above for the part number..but verify as you never know the part number may have changed.
astecasphaltman
6.7L Power Stroke Diesel
18
Sep 12, 2019 07:32 AM
jwalker_52
2009 - 2014 F150
Dec 5, 2018 05:37 AM
Custer28
Apr 11, 2018 03:10 PM
mhofmann86
Sep 22, 2015 03:45 AM
cgarym7
Mar 9, 2009 02:02 AM
