1995f150-351W
Old Nov 12, 2022 | 08:18 AM
VanMccabe01!'s Avatar
VanMccabe01!
1st Gear
1995f150-351W
Rebuilt the truck from the ground up. New everything. When starting truck will fire right up, run for10 seconds or so and shut down. Subsequent starting attempts result in firing but running rough for about 5 seconds then no start. New pumps seem to be holding around 40 psi. Help
Old Nov 12, 2022 | 10:03 AM
Prototypemech's Avatar
Prototypemech
Have you tried starting your truck with the SPOUT connector removed?
Also, make sure you're EGR valve is closed.
Old Nov 13, 2022 | 09:55 AM
Prototypemech
Oh. I know what you did. You plumbed the EGR valve directly to the intake manifold vacuum, so when the engine starts, the EGR valve opens up and kills the engine.
Newbie123
Aug 12, 2021 05:27 AM
schneidballs
Jul 24, 2015 02:03 PM
balzdeep05'
Dec 31, 2011 08:23 PM
dfernander
1983 - 2012 Ranger & B-Series
Oct 21, 2007 09:55 AM
phordphella
Feb 1, 2006 07:31 PM
