Headlight relay harness
Old Nov 13, 2022 | 01:18 PM
  #31
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by Tpayne621
I was part of the trying to convince him to get the wiring harness crew. I'm not the OP. 😂
Oops. To @kd5zll , what he said!
Old Nov 23, 2022 | 09:07 AM
  #32
kd5zll's Avatar
kd5zll
Got my parts in, lenses, bulbs, ceramic pigtails.... but one relag looks like someone stomped it... so i have to replace that, obviously. Hopefully, have brighter, properly aimed headlamps by the end of this weekend.
Old Nov 24, 2022 | 08:28 AM
  #33
kd5zll's Avatar
kd5zll
Point of clarity. Relay 1 is triggered by power on, for low beams, and relay 2 is triggered by the high beam selection. So each relay runs both bulbs, just for the different tasks, correct?
Old Nov 24, 2022 | 08:45 AM
  #34
FordTruckNoob
Correctamundo.
Old Nov 24, 2022 | 08:50 AM
  #35
kd5zll's Avatar
kd5zll
Since im going with these 70 amp relays.... i assume i have the capacity to add some extra lights. Considering a fog lamp for low beams, and a couple long range focused lights for high beams.
Thinking to let them power through the relay, but put in cut off toggles in the cab so i can turn the extra lighting off, appropriate to the situation. Opinions welcome. Light recomendations sought.
Old Nov 24, 2022 | 08:56 AM
  #36
FordTruckNoob
You may want to run a third relay for the auxiliary lights. Better to switch a relay than the full current going to the bulbs.
Old Nov 24, 2022 | 09:01 AM
  #37
kd5zll's Avatar
kd5zll
i guess that would be two more relays, one for the fog light, and one for the long reach. Though i suppose i could run the trigger to them with the same switch. Since power conditions would be different entirely.
Old Nov 24, 2022 | 09:26 AM
  #38
FordTruckNoob
Yeah. There are many ways this can be configured.
Have you considered knuckle lights?
https://www.extremeterrain.com/gatek...E&gclsrc=aw.ds
Old Nov 24, 2022 | 09:29 AM
  #39
kd5zll's Avatar
kd5zll
Those are really cool. Hadnt seen those before.
Old Nov 25, 2022 | 06:57 AM
  #40
RacinJasonWV's Avatar
RacinJasonWV
In this case I would probably trigger these additional relays by the grounds with 1 switch to activate the aux lights. The hot side trigger coming from either the switched or output of your other main relays.
Old Nov 25, 2022 | 08:07 AM
  #41
SkySkiJason's Avatar
SkySkiJason
This requires the switch to handle the full amperage of the circuit. Specifically what we avoid with relays....
First, determine if you ‘need’ more light after the mods.
If you want more light, build a duplicate harness and use the other factory headlight pigtail to trigger the relays for fogs and driving lights.
I prefer to use 3-position switches (on-off-on) for these. This gives you the ability to leave them OFF, ON or ON-with hi/lo beams.
Old Nov 25, 2022 | 12:15 PM
  #42
GavinAtkins's Avatar
GavinAtkins
I was running those bulbs, gotta make sure you have high quality housings. Mine were china made and didn’t live real long under the heat.
Old Nov 25, 2022 | 12:25 PM
  #43
kd5zll's Avatar
kd5zll
Fair enough. I figure im more likely to add fog lights, than long range, and that, mostly due to wanting the lower placement, more than just needing more light..
Old Nov 26, 2022 | 04:39 PM
  #44
kd5zll's Avatar
kd5zll
Just on the fyi, i found the ⅜ female disconnects, at auto zone. They are straight type, rather than the 90 degree/flag type. But still.
dustyroad
17
Mar 30, 2020 11:19 AM
bkuuz1
6.7L Power Stroke Diesel
Sep 17, 2017 06:48 AM
Harrier
Sep 20, 2015 08:45 PM
88dually
Feb 22, 2014 08:10 AM
Lifted94XLT
Kansas Chapter
30
Feb 29, 2004 12:45 AM
