Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C700 1976 Help
Old Nov 10, 2022 | 07:08 AM
Topsykidd23's Avatar
Topsykidd23
8th Gear
C700 1976 Help
C70wvc16650
Is my vin. Ive tried using all kinds of decoders but i cannot identify the motor code. Can someone please help?
Old Nov 10, 2022 | 01:37 PM
85e150's Avatar
85e150
Welcome to FTE!
C70 = C700 gas
W = 361 2V or 4V, both "Low propane gas - D.S.O"
V = Kentucky Truck Plant
C16650 = 1976 numerical series, April 1976 production
Old Nov 10, 2022 | 05:39 PM
Topsykidd23
8th Gear
361? Low propane gas - D.S.O?
Im having issues getting the poor thing started again.
Old Nov 10, 2022 | 07:38 PM
85e150's Avatar
85e150
As OEM, it was a Domestic Special Order, and ran on propane, and if I'm reading it right, had low compression to boot. (lower than the standard low compression)
Is this thing converted back to gas? Have you checked for spark, gas, air, vacuum leaks, timing, anything change recently?
Old Nov 10, 2022 | 08:32 PM
Topsykidd23
8th Gear
Yes it is running on gas. I just bought it, Running great. Drove about 100miles and died right after filling up. Treated the fuel with seafoam. Replaced Coil and Battery. Fixed a leak on the 4100 Carb it has. I see no indications it was once running on propane..
Old Nov 11, 2022 | 12:20 AM
85e150's Avatar
85e150
As an OEM gas truck, it would have had a Holley carb. As a propane truck, probably a propane carb.
Spark, gas? Fuel tank clean? Fuel filter in place?
Old Nov 13, 2022 | 08:27 AM
Topsykidd23
8th Gear
It has a 4100 autolite carb. From what I understand they came stock on alot of these motors. Today I'm going to be tearing into the truck again.
Replacing the fouled plugs. New wires. New distributor cap, rotor and points.
fslay
Large Truck
May 24, 2021 03:58 AM
ByersFarm
May 27, 2014 12:08 PM
deabolt
Sep 6, 2004 11:13 AM
rustyf100
23
Apr 28, 2003 01:07 PM
