2016 F250 diesel. I get a dash light that says "Service Traction Control Soon". I have not called Ford yet, thought I would throw it out here first. In the manual it talks about turning traction control on or off on the dash board, but I cant find anything talking about servicing it. ??
That would be a dealership service department item.
But, there are things you can try to avoid a trip to the dealer.
Are all of your ABS sensors plugged in and working? Have you scanned for error codes? Is your speedometer working correctly? Have you looked around under the truck to see if there is any damaged wiring harnesses? Are you able to turn traction control off and back on?
