Sponsored by: Auxito
No throttle
Old Nov 9, 2022 | 09:11 AM
David M Keller's Avatar
David M Keller
1st Gear
No throttle
I have a 2002 F250 with 7.3L diesel. I have check engine light on and no throttle response. It starts and idles.
I have already replaced throttle assembly and still have check engine light and no response.
I just recently replaced 2 injectors not sure if that could be an issue so I wanted to include that.
is There a corresponding fuse or relay, or is it something else?
Old Nov 10, 2022 | 06:54 AM
manicmechanic007's Avatar
manicmechanic007
A code reader you need
Was it an aftermarket pedal assembly?
You need to be able to run the TP PID
Most cheap scan tools these days read about 25-40 pids and TP should be there on all of them
Good luck
SpencerMurphy
Jul 2, 2022 07:41 PM
jdevlin
Mar 20, 2011 08:10 PM
kenndd
Oct 20, 2009 09:52 PM
superpony18
Oct 11, 2008 09:57 PM
