That housing isn't very thick, and should've been 7/16 20, so it wouldn't take much to twist a 7/16 14 bolt into it, might try a 7/16 20 and some lock tight, see if it will snug down tight.
Thanks.
I just ordered this: Mopar Rearend Vent Bolt I'll carefully add some weld to it, get it turned to size on a lathe, and then run a die on it to 14 t.p.i.
