95 Ford F-150 running problem
Old Nov 7, 2022 | 08:10 PM
Setjohns's Avatar
Setjohns
2nd Gear
Hello everyone, I recently changed out my timing gears and chain on my 95 ford F-150 with a 5.0. It ran fine before my timing chain had its issue but now when I start it, it runs for 15-30 seconds then dies. First I'm baffled by why this is happening in the first place since the timing is good and that's all I did was the timing gears and chain. I never messed with the fuel system on it or anything else I can think of that could be causing this issue. I have changed the fuel filter and I can hear both pumps working when switching between tanks. Is there another fuel pump somewhere else that I'm not seeing? I also bought a fuel pressure gauge but haven't had much luck with it working. Dang harbor freight! Would anyone have any other ideas as to what might be the problem?
Old Nov 13, 2022 | 09:23 PM
Setjohns's Avatar
Setjohns
2nd Gear
I have replaced fuel pump, fuel filter, spark plugs, and it still runs only for a few seconds then dies. I am at a loss. I have went through all the wiring to make sure nothing was loose. Can anyone please help me out.
Old Nov 15, 2022 | 11:02 PM
xlt4wd90's Avatar
xlt4wd90
Have you run an EEC self test yet? Start there, and maybe it will point out something that's not normal.
Did you ever get a working fuel pressure gauge?
makuloco2000
2009 - 2014 F150
Nov 10, 2014 12:11 AM
tcbofade
Jul 21, 2008 09:19 AM
Fords&Farmalls
Dec 29, 2007 02:05 PM
bigun72
Feb 20, 2007 09:07 PM
SgtRock
Bronco II
Sep 13, 2004 12:11 AM
