Suggestions needed
Old Nov 7, 2022 | 06:27 PM
ynot321AB1's Avatar
ynot321AB1
Suggestions needed
I am starting to put a 239 back together and am at the point of putting on the retaining clips, (not the proper term), see pics, onto the caps of the connecting rods. I have come up short on these clips and am wondering if I could use Loctite on the two caps in lieu of the retaining clips shown, I have enough retaining nuts for 6 of the pistons leaving me 2 pistons that i am thinking of using Loctite on instead of the retaining clips. Would it be better to remove the other retaining clips and use Loctite on all caps instead of just the two that I am missing the clips for?
Any info would be greatly apricated.
Old Nov 7, 2022 | 08:19 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Vanpelt sales has the jam nuts. Part # 45218-S8, $0.40 each.
Ford Engine Parts Prices Page 2 (vanpeltsales.com)
Old Nov 7, 2022 | 09:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The "palnuts" aren't really necessary. Ford quit using them at some point. About half the flatheads I've taken apart have them, half don't.
Old Nov 8, 2022 | 07:33 AM
ynot321AB1's Avatar
ynot321AB1
Thank you for the info, so I can get away with just the nuts? Would it be a good idea to put locktite on them or just torque them to specs and leave it at that?
Old Nov 8, 2022 | 07:35 AM
ynot321AB1's Avatar
ynot321AB1
Do you just snug the jam nuts against the original nut?
Old Nov 8, 2022 | 10:14 AM
ALBUQ F-1's Avatar
ALBUQ F-1
No Loctite needed. I've never seen a spec for the jam nuts' torque, they are pretty flimsy so maybe 15 - 20 ft-lbs?
Did you ever get new rods? If they came with the nuts, I would use them "just because". Have you checked your local NAPA or hardware store? Except that they are fine thread, they are a pretty common item.
SkySkiJason
89
Apr 1, 2023 06:44 PM
crazy96863
41
Nov 27, 2012 07:34 AM
Callmed
Mar 13, 2012 09:59 AM
KYFord
1983 - 2012 Ranger & B-Series
Jun 8, 2004 09:13 PM
