Steering column loose
Old Nov 5, 2022 | 06:38 PM
Apocalypse Truck's Avatar
Apocalypse Truck
Hello,
1997 Ford F250, 5.8L 351W, RWD
The entire steering wheel is a bit loose and moves back and forth. The two videos show what I mean and where I see movement. The image shown below is what seems to be loose, but when I tightened that bolt, nothing changed.
The whole truck was taken apart and put back together 1,000 miles ago and it's been running good. This just happened out of the blue.
Have any of you run into this before? I can start taking it apart, but I wanted to do some research before I got too far down the rabbit hole.
I'll be happy to supply more pictures if needed.
File Type: mov
File Type: mov
Old Nov 5, 2022 | 06:44 PM
Prototypemech's Avatar
Prototypemech
I'm interested in how you're gunna repair this, because mine does that too.
Old Nov 6, 2022 | 04:26 AM
tjc transport's Avatar
tjc transport
i ain't rite
i am going to say worn out bushings between the clamping bolts.
although i have never run into that before.
Old Nov 6, 2022 | 05:55 AM
toolman60's Avatar
toolman60
The bushing is not fully seated into the bracket may be playing a part of the problem along with possible worn or split bushing.
Old Nov 10, 2022 | 11:41 PM
Apocalypse Truck
Sooooo, here's my update.
I took all of my panels off. I figured I would change my blinker while I was there. IT WORKS SO MUCH BETTER NOW.
But the loose steering column was not completely resolved. I loosened up those bolts, but there wasn't any obvious problem. Maybe if I took the whole steering column off, I would be able to see what the problem is.
For now, I just tightened the hell out of them and it seems to be doing fine.
To get to the point where it didn't make noise, I had to tighten, test, loosen, tighten, fiddle, test some more, fiddle, loosen, tighten and pray. That exact sequence seemed to work for me. No more shaking back and forth or noise coming from the steering column.
But honestly, I'm super happy about my blinker. Sometimes it's the small things in life.
Old Nov 29, 2022 | 06:43 AM
Apocalypse Truck
Here's an update after fixing it and driving it for a while.
The only thing I really did was loosen and tighten the bolts until there was no play in the steering wheel. I no longer hear a clunking noise when I am turning.
I wasn't able to get the bushings to sit properly or even figure out what part needs to be replaced.
But my problem is solved.
Old Nov 29, 2022 | 10:28 AM
Prototypemech
Thx @Apocalypse Truck . I'll try that on mine.
theswagg
Oct 20, 2022 06:09 PM
moveoverGM
Feb 4, 2022 11:50 AM
mytoolman
Dec 23, 2021 02:06 PM
Koehn
Jun 27, 2021 02:29 PM
Patina65
May 11, 2021 04:33 PM
