1978 neutral safety switch replacement
Old Mar 12, 2023 | 11:55 PM
1TonBasecamp's Avatar
1TonBasecamp
OK. Sounds good. Sorry, I misunderstood the original post.
When you use the power probe, or a voltmeter, do you sense voltage coming from the ignition switch side of the harness when the key is in the ON position? It probably works in the ACC position as well, but in the on/run position for sure.
If you’re not getting 12 V on one of the backup lamp wires, then there is something missing somewhere else.
Maybe one of the fuses has blown? I think there is a fuse for the back up lamps. Especially if you have one of the later fuse panels with 10 fuses instead of the small one with five.
Old Mar 28, 2023 | 06:31 PM
Cekelley81's Avatar
Cekelley81
4th Gear
Solved
Switch was aligned perfectly so I stsrted back tracking all the way to the fuse panel. Fuse was good but I had 12v on one side and nothing on the other. Turns out the block pins had corrosion. I cleaned it all up and they now work
Old Mar 29, 2023 | 12:31 PM
1TonBasecamp
Great!
good to hear it was something simple. And this comes up a lot with the old glass fuses.
If you didn’t already do that to all the other fuses, you might as well. This is something that every owner of an old vehicle should do every couple of years.
Remove the fuses, wipe them down and clean the contacts, put them back in.
Does usually keep some of these gremlins from popping up now and then.
Old Mar 29, 2023 | 01:32 PM
Zag78F150's Avatar
Zag78F150
So with my 78, I sometimes have to wiggle the shift lever to get it to start. Could this most likely be my issue?
Old Mar 29, 2023 | 03:45 PM
1TonBasecamp
With the glass fuses? No. But with the neutral-safety switch? Yes indeed.
Regarding the glass fuse corrosion, you would still want to do what I mentioned about cleaning them now and then, but the clue of having to jiggle the shift lever sounds more like the NSS coming out of adjustment.
Easy enough to find out though. I did not re-read the thread, but if we discussed how to adjust the NSS on the side of the transmission, perform that adjustment and let us know if anything changes.
Your '78 would have one on the side of the C6 where the shift lever is. Can't say for an F150, but on the 250 and 350 models, it's a royal pain to get to sometimes!
Yours a 2wd or 4wd?
Paul
Denty
Apr 27, 2021 02:02 AM
White76
Apr 8, 2013 10:30 AM
80FlareSide
Oct 7, 2010 04:32 PM
RICHMC54
Dec 5, 2004 05:18 AM
gbeach
Oct 14, 2004 02:54 PM
