Oil Filter Housing Question
Old Nov 3, 2022 | 12:55 PM
1ole4d's Avatar
1ole4d
I'm putting a 302 from a 1996 Exploder (yes, I spelled it like that on purpose) into my 1989 F150 4x4. The Exp motor has an oil cooler adapter mounted where the filter would normally screw in straight. It angles the filter forward and utilizes a shorter filter. Is there clearance for this setup to work on these trucks or do I need to pick up and adapter to convert it back to the convention side mount?
Old Nov 3, 2022 | 01:54 PM
jernigan's Avatar
jernigan
I have a 90 model f150 and did the same engine swap except mine came from a 99 explorer. All I did was remove the adapter from the donor motor, and on your old motor after you remove the oil filter you will see what looks like a pipe nipple. Just remove it and thread it in you donor motor. Them you can use your original style filter, Hope this helps.
Old Nov 3, 2022 | 02:46 PM
1ole4d's Avatar
1ole4d
That part I get. I'm wondering if the Explorer setup will fit in these trucks or if I have to ditch it. I like the idea of having an oil cooler setup like this but if it won't fit then I'll just remove it and hang on to it for now.
Old Nov 4, 2022 | 01:35 AM
wwhite's Avatar
wwhite
I'd ditch it. Someone mentioned to me that if the adapter fails, you get coolant in your oil.
Old Nov 4, 2022 | 07:44 AM
Hit Man X's Avatar
Hit Man X
I would also junk it. KISS for the swap and I fail to see how a 302 can do enough work to necessitate an oil cooler.
Old Nov 4, 2022 | 07:51 AM
1ole4d's Avatar
1ole4d
Understood. One less thing to worry about going bad.
mattymax
Jun 9, 2022 10:37 PM
72CC428
May 2, 2016 08:05 PM
Kurtboyd
Aug 28, 2013 12:23 PM
05 f250 6 inch lift
Sep 25, 2012 08:20 PM
allisonmo2
Feb 23, 2009 06:22 AM
