2002 E350 blown plug Triton 6.8
Mechanic says the #2 plug on pass side is blown and took threads with it and is in a bad location to get to. R&R engine and remove and replace with new head(s)? Or is there another way to effect the repair? If R&R engine is necessary, is there anything else I should have done while it's out? (I'm pretty sure I have a valve cover gasket leak-so I'd have that done) No previous mechanical work on it except for replacing a few coils. Van has 306K miles. I've had it 19 of it's 20 years - a member of the family.
From what I've read here IF the engine needs R&R it would be the perfect time to renew the exhaust manifold studs, using Ford's new and improved stainless steel parts.
I would seek a second opinion whether the existing head is indeed trashed, perhaps contact Blownsparkplugs.com checking if they have a recommended installer of their systems. Just from what little I know the #2 spark plug on a V10 in an F-Series hasn't been even nearly impossible to replace with a Timesert or similar part.
The following users liked this post:
coolfeet
05-18-2020 05:14 AM
videopro192
15
02-01-2010 03:02 PM
scarl
08-29-2003 08:05 PM
