What's a good trick?
Old Oct 31, 2022 | 04:46 PM
diggerrigger's Avatar
diggerrigger
4R70W gear selector switch rusted tight to the shaft. I have hit it with PB Blaster to soak. I would like to hear a trick to loosen and remove without breaking it.
Old Nov 1, 2022 | 05:00 AM
JWA's Avatar
JWA
I would disconnect the wiring harness and try squiring a bit of Kroil onto the bolt between the frame and the switch body. I'm assuming there is a metal bushing running through the switch body? OR you might try removing the rusted washer from the mounting bolt with a chisel to see if that allows the switch body to slide free? I think I see just enough of a shoulder you could fit a chisel?
Not sure otherwise---good luck with this.
97vanswap
Dec 13, 2021 12:48 PM
Miller513
Nov 16, 2021 07:46 AM
Destro1975
Mar 8, 2014 06:53 PM
strokin'_tatsch
Feb 12, 2011 11:48 AM
___
Aerostar
May 5, 2006 07:41 PM
