CPP power steering rag joint alignment
Old Oct 30, 2022 | 08:25 AM
bald59's Avatar
bald59
I have the steering box installed. It is flush with frame with no spacers, but the rag joint still seems slightly off to the right. I see no way to move it any farther to the left. How far off is too far?
Old Oct 31, 2022 | 08:47 AM
Byrd.Dog's Avatar
Byrd.Dog
Mine came with some bushings to put over the mounting bolts between the box & frame. They didn't look near stout enough for me, so I built a 3/4" solid metal plate spacer. Mine aligns almost perfectly with the steering shaft.
Old Oct 31, 2022 | 09:09 AM
bald59's Avatar
bald59
The box needs to angled to the left so spacing could only be in one or to bolts to get that angle. It has no spacers now and still not far enough in that direction.
Old Oct 31, 2022 | 12:46 PM
bald59's Avatar
bald59
So I put the spacers in and now the clutch slave will not go back in because of bolts on side of CPP box.
Old Oct 31, 2022 | 03:42 PM
Byrd.Dog's Avatar
Byrd.Dog
Here's some pics of mine:
They're a little dark, but the spacer plate actually looks to be about 1/2" thick & centers the column perfectly in the factory hole. My apologies about the clutch - I run a C6, so hadn't even thought about clearance issues with the slave cylinder.
Cougar54
May 24, 2021 05:13 PM
JMyers0901
Feb 25, 2013 05:27 PM
Freightrain
Aug 10, 2011 10:53 AM
Huggy Bear
Feb 23, 2002 08:28 AM
