Steering Rag Joints
Old May 24, 2021 | 12:34 PM
Cougar54's Avatar
Cougar54
Steering Rag Joints
I have installed a TCI Mustang II front suspension with power rack and pinion steering. Is it advisable to install a rag joint somewhere in the steering system or is it normally not needed? If needed, does it matter if it is installed either at the box input or at the end of the column? I might get away with only two steering shaft u-joints but not if I have to put a rag joint on the steering box.
Old May 24, 2021 | 02:58 PM
schoo's Avatar
schoo
Are you concerned about movement between the R&P and the cab? Or vibration?
I just installed mine with the jag it’s soft mount and used the jag Z joint. I would think that a rag joint is a step backwards
Old May 24, 2021 | 03:58 PM
Cougar54's Avatar
Cougar54
My initial thought was "Will I feel vibration in the steering wheel without one?" If the answer is "not likely", I'm good. I'm pretty sure now that I will be using three u-joints even without any rag joint.
OT - What diameter exhaust pipe are you using as you go next to your fuel tank? 2"?
Old May 24, 2021 | 04:21 PM
schoo's Avatar
schoo
Originally Posted by Cougar54
My initial thought was "Will I feel vibration in the steering wheel without one?" If the answer is "not likely", I'm good. I'm pretty sure now that I will be using three u-joints even without any rag joint. I don’t know m2 so no help
I used 2 1/4” all the way
Old May 24, 2021 | 04:46 PM
52 Merc's Avatar
52 Merc
On page 6 of the Borgeson Steering catalog linked here, there is a good explanation of vibration dampeners and how they work in steering components, along with options and information to help you decide what is best for your application.
http://borgeson.com/Images/100th_Catalog.pdf
Old May 24, 2021 | 05:13 PM
Cougar54's Avatar
Cougar54
Great information Wayne. Thanks.
bruno2
Mar 29, 2017 06:42 AM
iravogel
Mar 24, 2016 06:25 PM
Freightrain
Aug 10, 2011 10:53 AM
fordbeast_80
Dec 28, 2009 12:32 PM
Huggy Bear
Feb 23, 2002 08:28 AM
