Aerostar Ford Aerostar
Speed Sensor
Old Nov 12, 2003 | 02:01 PM
richandola's Avatar
richandola
Speed Sensor
Is the speed sensor the same part on a digital all wheel drive Aerostar as on a mechanical speedo 2 wheel drive? My speedo quit working and the tranny will not go into overdrive so I am trying to replace the speed sensor. I am having a heck of a time locating the sensor on my all wheel drive van. Any info would be appreciated.
Old Nov 12, 2003 | 03:46 PM
xrayjock's Avatar
xrayjock
The speed sensors and the speedometer shaft are all located on the transfer case. The rear shaft sensor is on top near output shaft. The front shaft sensor is located on driver side of transfer case on the top towards the rear of the case also. The speedo shaft is located on driver side of transfer case towards the front of the case.
Hope this helps
91 AWD 4.0 with 157,000 miles adding 25 miles every week day.
Old Nov 13, 2003 | 07:16 PM
AEROSTAR ALIVE's Avatar
AEROSTAR ALIVE
Sometimes the sensors are located on the actual axle above the input.
galute
Aug 19, 2020 05:04 AM
reddogracing
Nov 24, 2015 03:04 PM
Layson
29
Jun 4, 2013 12:27 PM
ErrorS
1978 - 1996 Big Bronco
May 13, 2011 08:51 PM
math427
Nov 10, 2008 07:38 AM
