250 Hitch insert
Old Oct 27, 2022 | 08:02 PM
tmtex's Avatar
tmtex
250 Hitch insert
Anyone know where I can get the insert for a 2.5 to a 2.0 that is flush. This one is a PITA to get lined up.
Old Oct 27, 2022 | 08:05 PM
jake415's Avatar
jake415
The Reese adaptor is flush mount
Old Oct 27, 2022 | 08:40 PM
number9xd's Avatar
number9xd
Yep, think that’s the one I’ve got. Honestly, I first bought one like OP shows, not realizing in the store that it wouldn’t be flush. When I installed it and seen it stuck out like that, I returned it and began the search for one that’s flush.
After getting it, and actually using it, I kinda wish I had the other one back. It’s aggravating trying to keep the flush adapter in place when sliding the hitch into it. Looking back, it probably would’ve been nice to have that inch to hold onto and keep the adapter in place. I’m just gonna rock on with it for now though.
At some point soon I’m gonna get a proper 2.5” hitch, because there seems to be a lot of slop stacking a 2” hitch, into the adapter, into the truck side.
Old Oct 27, 2022 | 08:57 PM
tmtex's Avatar
tmtex
Not seeing it on their web site. Holes dont match up
Old Oct 28, 2022 | 08:04 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
mine is flush, has a uhaul sticker on it.
Old Oct 28, 2022 | 08:22 AM
scraprat's Avatar
scraprat
Top Answer: 5
I've been using a hitch tightener to eliminate the little bit of slop which it has done.
Old Oct 28, 2022 | 08:28 AM
CheeseheadFord's Avatar
CheeseheadFord
If you tow a lot just bite the bullet and buy the correct sized hitch, the sleeves I've tried were all garbage and just a waste of money.
Old Oct 28, 2022 | 08:33 AM
scraprat's Avatar
scraprat
Top Answer: 5
If starting fresh with no hitch it would be easier to get the size to fit. If already having hitches it was easier to get the tightener if the slop bothered a person.
Old Oct 28, 2022 | 08:35 AM
CheeseheadFord
Also don't forget a strain hitch pin, those J pins like to wallow out the hitch pin holes.
Old Oct 28, 2022 | 08:38 AM
scraprat's Avatar
scraprat
Top Answer: 5
J pins are junk. Might as well get straight pin with a lock on it.
Old Oct 28, 2022 | 08:53 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I have yet to understand why Ford doesn't offer a reducer with their trucks. My Ram came with one, holes line up perfectly, almost no slop between the sleeve and the receiver (can't say the same for all hitches), and it's got about a half-inch long flange to keep it from sliding in too far. It's been in there so long it might be rusted in place, I'm not actually sure - I switch hitches and it never even tries to pull out now.
Ford's missing out by not offering one that's matched to the trucks.
Old Oct 28, 2022 | 09:08 AM
scraprat's Avatar
scraprat
Top Answer: 5
Ford use to give the sleeve and it did fit perfect.
Blackwaterforge
Feb 28, 2022 07:35 PM
System
Feb 16, 2017 09:38 AM
Curated Content Editor
All Things Towing
Aug 10, 2016 04:11 PM
kkubina
All Things Towing
Jul 6, 2015 02:57 PM
