Aftermarket Products
Sponsored by: Worksport
ARB Wire Harness CKMA12 Modification
Old Oct 27, 2022 | 11:12 AM
zeeroecool's Avatar
zeeroecool
7th Gear
I have the CKMA12 ARB high performance on-board compressor (the single), and I am looking to connect it directly to a 40 amp upfitter switch. Doing so would make the relay unnecessary. I will only be using this for airing up tires and not for lockers. How would I need to modify the harness?
Old Nov 3, 2022 | 08:38 AM
eaglelope's Avatar
eaglelope
7th Gear
I am about to wire one up myself (it should arrive today). I think you will still need the relay in order to use the pressure switch. The pressure switch can't handle the motor current alone so it will need to control the relay.
You can wire power to the relay contacts and to the coil with the same wire from the upfitter. The pressure switch will need to be in series with the relay coil.
Will Morrow
Mar 31, 2021 07:23 AM
transam525
May 30, 2019 10:00 AM
WALFORD'S 56
Apr 3, 2014 01:04 PM
Pitcrw6
Aug 26, 2012 12:59 PM
porthole
6.7L Power Stroke Diesel
May 16, 2012 06:34 PM
