Best cam/ timing options
Old Oct 26, 2022 | 10:33 PM
Jnr96's Avatar
Jnr96
I know I know I know.... it has been discussed a thousand times. I've spent hours scouring the forums but can't really find a straight answer with all the information I need to make a purchase. I have a 460 out of a 1973 RV thats going into a 1979 f150 with a c6 and I believe 3.50 gears. Don't care too much about gas seeing as its a 460... What I want is good low end torque and midrange. I currently have the engine out of the truck for an overhaul (plan on replacing all seals and wear items). Im going to switch to pre-emission straight up timing gears. I plan on grinding the bumps out of the heads, but otherwise sticking with the D3ve stock heads. I currently have a 650cfm carb but I can get a better flowing one if its worth it, as well as getting a better intake if its worth it, perhaps an edelbrock performer. So my question is, with the stock heads and restrictive bumps ground out, a performer intake, but otherwise stock engine: what's the best cam timing to look for? is a cam even worth it? Is there anything else worth doing while I have the engine apart that wont break the bank?
Old Oct 27, 2022 | 01:42 AM
5speed65's Avatar
5speed65
Scotty jay otherwise known as the mad porter on the ford 460 forum has a package perfect for low end torque on 87 octane
Old Oct 27, 2022 | 08:04 AM
Jnr96's Avatar
Jnr96
any chance you have a link?
Old Oct 27, 2022 | 08:27 AM
Jnr96's Avatar
Jnr96
nevermind, I found him. Thanks!
Old Oct 27, 2022 | 09:06 AM
440 sixpack's Avatar
440 sixpack
The best advice you're going to get on a cam is this right here. talk to Brent Lykins and Lykins motorsports and have him order you a custom cam for your exact application.
I highly recommend a roller cam if you can swing a little extra money it's worth every penny. but he'll do a flat tappet if you want.
Old Oct 27, 2022 | 11:30 AM
79F150400M's Avatar
79F150400M
I went with a Milodon timing set for an early 70's 460. Lined up the dots...and put it all back together and it runs like a Swiss watch. Stayed with the stock bump stick but I did go with an Edelbrock Performer and Edelbrock 750 carb with a one inch phenolic spacer.
Old Oct 27, 2022 | 12:05 PM
redroad's Avatar
redroad
@ 79 F150400M Great engine bay shot. It has been a while since I've seen an OEM aux. battery tray in the wild. Is that what I'm looking at ? Also get rid of the clear plastic fuel filter sitting on top of the intake exhaust crossover in one of the hottest running power plants made by Ford. That's your weak link there. The fuel pressure regulator is a nice touch. Now put a fuel pressure gauge where that brass plug is now.
Old Oct 27, 2022 | 12:14 PM
79F150400M's Avatar
79F150400M
Originally Posted by redroad
Great engine bay shot. It has been a while since I've seen an OEM aux. battery tray in the wild. Also get rid of the clear plastic fuel filter sitting on top of the intake exhaust crossover in one of the hottest running power plants made by Ford. That's your weak link there. The fuel pressure regulator is a nice touch. Now put a fuel pressure gauge where that brass plug is now.
Oh...hey thanks for the safety tip on the plastic filter...guess I need to procure a metal one. Had to go with the Holley FPR to run the Eddy carb...stock fuel pump caused flooding under 1500rpm. The OEM aux battery tray is one I bought from a member here on this forum...as the original was a corroded mess. One day I'd like to get that feature working again. It's not a huge priority as the truck will probably never haul a slide in camper again or tow any 5th wheel trailers. The P.O hacked up the wiring a bit but nothing I can't figure out.
B327Thr
Oct 24, 2018 12:59 AM
Greg9321
Feb 27, 2013 04:20 PM
F250Nelius
Jul 10, 2012 07:17 PM
76cougar74100
Sep 17, 2006 02:38 PM
brandonkv
Nov 26, 2004 07:27 AM
