HELP!!
Old Oct 26, 2022 | 03:28 PM
dexstang's Avatar
dexstang
3rd Gear
HELP!!
Was driving down hi way and my engine died. It cranks but won't fire. I tried to clear codes and it didn't work. p603, p132B, p2287
6.0 Studded
*glow plugs - water pump - idlers at 175k
*6.4 starter at 201k
*Adrenaline billet HPOP, quick connect fittings re oringed, all injectors re-oringed, IPR valve, ICP sensor, injector harness, intake gaskets, valve cover gaskets, coolant flush, oil cooler flush. 203,700
*new “redhead” steering gear, motorcraft power steering pump, XRF tie rod and drag link with all ends, passenger side Mevotec upper and lower ball joints. Full alignment. 207,989
Old Oct 26, 2022 | 03:57 PM
bismic's Avatar
bismic
Did you replace the ICP sensor connector and pigtail? This is likely the no-start issue.
Monitor ICP sensor volts.
P0132B is a code related to the calibration from the recall 06E17 (part of the Inferred EBP strategy). It means that there is a problem with the VGT system.. P0132b will be set if the PCM determines that there is something wrong with what it learned for MAP and MAF as it relates to VGT duty cycle.
Could be: issues with turbocharger, MAF sensor, MAP sensor/hose, intake leaks, exhaust leaks, etc. Could also be related to the EGR system.
Still have an active EGR system? Verify that the EGR valve is not stuck open.
Old Oct 26, 2022 | 04:41 PM
dexstang's Avatar
dexstang
3rd Gear
Ill see where I can buy that sensor.. Napa maybe?
no EGR.
Old Oct 26, 2022 | 04:56 PM
bismic's Avatar
bismic
You had posted that the ICP sensor was replaced, but sometimes the heat on an 03 engine (ICP is very close to the turbo) can ruin the connector or even the wiring.
A new pigtail is best bought from a dealership IMO: part #5C3Z-12224-A
That said, I would inspect it before replacing it, but I know it is in a difficult to access area. I would also monitor the ICP sensor volts before replacing. for that you need a monitor. If you don;t have a monitor you need to get one.
ForScan is one of the best and cheap. $6 download (max) and an OBDII adapter can be obtained for as little as $40 - depending on the device you want to download to.
Old Oct 28, 2022 | 03:24 PM
dexstang's Avatar
dexstang
3rd Gear
Sensors were all good. Fuel wasn't getting delivered. Tank is full and showed empty on gauge..
gitschlag
19
Nov 12, 2021 03:01 PM
Rengland2008
Jun 18, 2016 10:55 PM
smokey98
Dec 6, 2008 07:57 PM
OTTOMATIC
Oct 14, 2008 08:38 AM
sedly
Feb 28, 2008 02:13 PM
