Headlights and dashboard lights flicker on 1966 f100
Old 10-24-2022, 01:14 PM
mytruckisa1966's Avatar
mytruckisa1966
mytruckisa1966 is offline
8th Gear
Hi All,
I am new to the community and have already found it very informative and helpful. Thank you much for sharing your experiences. I have a 66 f100 basic model, 6cyl, 3 spd. The headlights and internal dashboard lights pulsate - never going out totally - just brightness dims slightly and rapidly. In general, the head lights are not far reaching, and I would like to brighten them up. In reading various threads, I have seen reference/link to an article on 'whiter is white and brighter is bright' that owners have used to get to brighter lights.
Two questions:
1) when using the links to the article (looks to be back in 2013), the links do not work. Would anyone have a link or a local copy of the article to share?
2) if I do what the article states do you think it would solve the pulsating? Maybe I need to work the two needs independently?
Very much appreciate your thoughts.
I look forward to learning and sharing.
Old 10-24-2022, 02:01 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
You’ll need to get your flickering problems solved prior to upgrading the headlights. I bought a set of Hella E-Code halogen headlights, and a new upgraded headlight harness from Tom’s Bronco Parts. That harness has fuses and relays integral in the harness, allowing you pull, essentially, two new circuits directly from your battery. That greatly reduces the current the length of the path the electricity has to take to reach your headlights, meaning much less voltage drop. The wires used in the harness are also larger, also lowering the resistance and voltage drop. You will have much brighter headlights. Also, the harness from Tom’s comes with a diode which, if you leave it installed, allows the use of both high and low beams at the same time.
The E-code Hellas I bought from Susquehanna MotorSports, but you can source them many places. You can even use higher wattage lamps, if you dare. I am happy with the stock wattage lamps , they are vey bright when running both high and low beams at the same time.
The following users liked this post:
Old 10-24-2022, 02:36 PM
wtx66f100's Avatar
wtx66f100
wtx66f100 is offline
Thinkin this might be the article you were referring to.
Old 10-24-2022, 04:19 PM
Tom H So. Ca.'s Avatar
Tom H So. Ca.
Tom H So. Ca. is offline
Do the lights flicker or pulse only at idle or all the time?
At idle the alternator or generator may not be putting out enough power or the regulator could be going bad.
Tom
Old 10-24-2022, 06:17 PM
john jamieson's Avatar
john jamieson
john jamieson is offline
Probably need to check and clean all the main electrical connections and grounds. X2 on the headlight relay harness. I put one in my 66 and it helped greatly.
Old 10-26-2022, 09:10 PM
mytruckisa1966
8th Gear
Thank you for the information on brightening up the lights, will head to working the pulsating and then onto the brightness.
Old 10-26-2022, 09:21 PM
mytruckisa1966
8th Gear
Bingo! Thank you wtx66f100 - it worked!
Old 10-26-2022, 09:23 PM
mytruckisa1966
8th Gear
Hey John - will give that a try. Can you expand on what you mean with 'X2'?
Old 10-28-2022, 05:32 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
Received 2,171 Likes on 1,843 Posts
That he seconds the head light relays and I will X3 (3rd) that as I have a relay kit in my 81 F100.
Now Icant say if it helped as I added them before the truck was put on the road but I love the head lights on it over my 02 Durango that are junk from day 1.
Dave ----
ps what was the fix?
I cant get the link to open as the page gets locked,might be this old laptop I am on?
Old 11-06-2022, 12:06 AM
mytruckisa1966
8th Gear
Hi Tom,
Lights steady out at higher rpm. Thinking to start with voltage regulator and get my alternator checked out.
Thanks much!
Old 12-03-2022, 03:45 PM
Mr. Rogers's Avatar
Mr. Rogers
Mr. Rogers is offline
Dimmer switch
When mine did this I found a dirty connection on the dimmer switch.
here a diagram link
http://www.fordification.info/tech/wiring_66.htm
Old 12-04-2022, 09:32 PM
mytruckisa1966
8th Gear
Thank you Mr. Rogers - will give it a try
Old 12-04-2022, 09:46 PM
mytruckisa1966
8th Gear
Thanks much - the pdf that was provided I was able to open it.
Old 12-22-2022, 01:05 PM
William's Avatar
William
William is offline
I use one wire Delco alternators and ditch all the rotten wiring, worn alternator and voltage regulator. I would also recommend replacing old switches with new switches from the numerous suppliers currently available. I'd start with a new dimmer switch. I also make new battery, starter and ground cables. I also add a good ground between the cab and frame and another between the engine block and frame. This will solve a lot of mystery electrical issues. Take a few minutes and pull the bulkhead connectors on the fire wall and clean them up with a wire brush and carb cleaner, add a liberal amount of dielectric grease.
Tyler11T
Appearance & Dress-Up
06-08-2018 11:29 AM
thenukemaster
16
08-30-2013 05:32 AM
jaye
01-21-2011 04:33 PM
paulm
03-18-2004 03:47 PM
Warhorse86
01-27-2004 10:31 AM
Quick Reply: Headlights and dashboard lights flicker on 1966 f100
