Rim bolt hole pattern
Old Oct 23, 2022 | 12:08 PM
timepiece's Avatar
timepiece
Does anyone know when Ford changed the bolt hole pattern from imperial to metric measurements ?
My truck is a 1988 so I know it was imperial then. I am shoping for some better rims and it would be
helpful to know.
Thanks
Old Oct 23, 2022 | 12:30 PM
Scndsin's Avatar
Scndsin
1996 was the last 5 x 5-1/2 on a F150.
Old Oct 23, 2022 | 02:57 PM
Scndsin's Avatar
Scndsin
You can also correct title by clicking edit button on original post.
Then, "go advanced" button & this will show title bar.
If you want.
Old Oct 23, 2022 | 04:01 PM
tjc transport's Avatar
tjc transport
i ain't rite
99 was the first year for metric. so you will want to look at 97 or older for rims to fit your 88
Old Oct 23, 2022 | 10:05 PM
solanum's Avatar
solanum
For F-Series over 8500 GVW, 1998 was the first year for Communist sized wheel lugs. Under 8500 GVW, it was 1997, the first year of the bubble-shaped F-150.
E-Series trucks use 9/16-18 wheel lugs to this very day in 2022!
Old Oct 24, 2022 | 09:58 AM
tjc transport
i ain't rite
there was no 88 full size f250 or 350 trucks.
he has a F250, so his year range is 97 and older.
Old Oct 24, 2022 | 10:30 AM
Conanski's Avatar
Conanski
To fit your truck correctly you want a '96 or older F150/Bronco wheel, the 5x135mm wheel used on some later F150s has the wrong offset so even if you did make it bolt on there would be tire rubbing issues. Some Dodge and Jeep vehicles also use the 5x5.5" bolt pattern but again I have found the wheel offset isn't ideal and in some cases the hub opening diameter is too small.
Old Oct 24, 2022 | 10:36 AM
Hit Man X's Avatar
Hit Man X
The 92+ factory forged alu Alcoas are inexpensive and common still. Best bang for buck to me in terms of strength, weight, and appearance.
Old Oct 24, 2022 | 10:59 AM
timepiece's Avatar
timepiece
thanks, did not know I could do that
Old Oct 24, 2022 | 11:36 AM
tjc transport
i ain't rite
he has a F250 with 8 lug wheels. F150 and bronco 5 lug wheels wheels will not work
Old Oct 24, 2022 | 06:15 PM
Conanski's Avatar
Conanski
Well I missed that point obviously.
Russronning
Oct 8, 2012 09:49 AM
josh33
1978 - 1996 Big Bronco
May 12, 2009 09:19 AM
bigbubba87
Nov 27, 2008 02:48 PM
penryn ford guy
13
Jan 2, 2008 12:36 AM
ken04
Jul 15, 2005 08:52 AM
