Hello everyone. I have been a long time user / first time poster after just joining. I ah a 2003 ford F350 Super duty 4 door 4X4 6.0. I have to replace my wind shield because of a leak. I was wondering / and thought I saw where a 2005 super duty wind shield would work. I think the leak is coming from the rubber seal around the glass. I was wanting to use a 2005 model wind shield that uses the black adhesive that they use from a gun. Thank you for your help
the front windshield is installed with the black adhesive on 99 and up SD. If you find a good windshield guy he should be able to
reseal the windshield. Try to get a good one. The cheap Chinese ones tend to have wavy glass and it’s annoying not only to see but when you wipe the rain the wipers can’t conform to the contours and you dont get a clean sweep.
the back window AFAIK are the old school rubber gasket no adhesive
