Rear SwayBar help
Old Oct 20, 2022 | 09:05 AM
02ExFilo's Avatar
02ExFilo
Rear SwayBar help
Did a forum search couldn't find much info.
I bought the ADDCO 2261 rear sway bar from SDsprings. This is the new style that mounts on the axel by the shock mount brackets all of this fits perfectly. I have seemed to have either bought the wrong end link or I am missing some type of mounting bracket on the frame as the end link I have is about 3-4inches short. EX didnt have a factory sway bar.
Endlink I have is MOOG K80161 center to center it is 5.75" in length this was said to be OEM for Ford Excursion but now I am not so sure that is true Now I have even found an AMAZON review saying it doesn't work wish I saw that earlier.
I am wondering if the F250 K80269, X15SL0352 will work as it is 12" center to center and has opposing ends. is the one I need before I purchase it and possibly be disappointed.
Thanks for the Help!
Old Oct 20, 2022 | 10:24 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Suggestion to get the help you seek.
1. call SD Springs to purchase correct item.
2. Make new links to suit your need.
3. Rotate your current bar/link so the links attach.
**pics are always helpful.
Old Oct 20, 2022 | 05:13 PM
02ExFilo's Avatar
02ExFilo
I ended up figuring out the issue hoping to have it installed by next week when the correct end links get in. I had the new springs put on this week and can't believe the lift I got vs the weak old springs. Gained 2.5"s on the front and about 3.5" on the rear now the *** doesn't sag and has a factory looking rake +0.75" to it. Love the look now I need 33" tires fill some wheel well space. I can actually hook up my 800# tongue weight camper to it and my hitch doesn't want to hit the ground LMAO
SpeedThrills
19
Jun 27, 2021 02:28 PM
dashstiffrod
Dec 23, 2019 08:03 AM
terrymargate
Dec 1, 2017 08:20 PM
NMSU_RRAggie
Mar 25, 2015 08:07 PM
harley4jcs
Feb 25, 2015 12:55 PM
