Sponsored by: Real Truck
Bouncing like crazy
Old Oct 22, 2022 | 11:44 AM
DesertSmoker's Avatar
DesertSmoker
Originally Posted by F350JOHN
Colorado guy here! My videos were filmed on I-25 in-between Castle Rock and the outskirts of Denver, by E-470. I've also had this happen up north around Ft. Collins.
I know that stretch of road very well. I could only go 55mph in that area both North bound and South Bound because the bucking was that bad in my 2010 but in my 03 I could keep up with the speed of traffic.
Old Oct 22, 2022 | 12:32 PM
'65Ford's Avatar
'65Ford
The bouncing in the youtube videos would be intolerable !
Make sure all the tires are round and not bulging in the tread. Tires sometimes do that especially as they get past 6-7 years old.
Old Oct 22, 2022 | 11:06 PM
F350JOHN's Avatar
F350JOHN
It can get extremely dangerous feeling if you're going too fast. You literally can bounce out of your seat! Many have suggested it to be a tire issue. But, I can say with certainty after testing multiple brands of tires, different sizes, and air pressures that it's spring related. The tires don't make a difference.
What I want to know, is it a known issue by Ford? Was there ever a TSB or recall? We need to solve this somehow.
Old Oct 23, 2022 | 05:30 AM
DRPS's Avatar
DRPS
Interesting read..
2 weeks ago I took my 2002 7.3 CC LB DWD 4x4 from orlando to the Ozarks to pick up a 25 foot 5th wheel.
When ever I hit those short expansion joints all hell broke loose.
It was crazy bucking. The bed weight was 900 pounds with a pull of 5,700 pounds.
Found if I ran faster it would minimize the buck. 65 mph.
When i got back and evaluated, i thought i was running with to high of presure in tires at 70 pounds. Making them bounce.
probably should have run at 55pounds approx. But not sure that would help.
The extra weight did zilch to help me.
But it's clearly an oscillation of road verses length of truck.
Old Oct 25, 2022 | 11:12 AM
Necronommicon's Avatar
Necronommicon
Drive today with 400# in the bed, right at the tailgate. Ride was definitely better, but still quite bouncy. Again, this truck does NOT have the TSB fix of that rubber gyroscope thing on the hitch. Tires are 55#. No noticable bouncing on black top roads at the same speed. Only new it newer concrete highway.
Old Oct 25, 2022 | 04:16 PM
DesertSmoker
Excellent results for your first test run. Now you can start to move your 400lbs load forward anywhere from 6 inches to a foot at a time and see where the truck rides the best. Next item to look at is your shocks. If you are running the stock Rancho 5000s you may want to consider installing a better shock.
Old Oct 25, 2022 | 04:19 PM
Necronommicon
Good info. I'm actually running new Bilstein 5100's. Starting to wonder if I should have gone with fox.
Old Oct 25, 2022 | 04:25 PM
DesertSmoker
Originally Posted by Necronommicon
Good info. I'm actually running new Bilstein 5100's. Staring to wonder if I should have gone with fox.
Both of those are way better than the Rancho 5000s so you are looking good. Yes I can admit I have been very interested in the Fox shocks.
Old Nov 11, 2022 | 07:44 AM
Necronommicon
So just an update for everyone. Did around 150 mile trip a day or so ago. On asphalt, at 80ish no bouncing at all. On concrete, same speed the same terrible bounce came back. 65psi in the tires, unloaded bed. Seems to be just on the concrete sections of the freeway that give me the issues.
TractorM3
Apr 1, 2009 06:20 AM
4bigred
All Things Towing
Jan 23, 2009 06:30 PM
BlackChamp
2004 - 2008 F150
Apr 18, 2007 12:07 PM
efoster_01
Jul 7, 2005 07:32 AM
