Battery charging
key features are the cig lighter plug and the suction cupsAmazon.com: SUNAPEX 20W 12V Portable Solar Battery Charger & Maintainer - Solar Panel -Built-in Intelligent Charge Controller-Solar Powered Charger for Automobile Car RV, etc… : Everything Else
I put the suction cups so they act like legs...and the panel which is about 12" by 12" just sits on my dash in front of my steering wheel. it has never moved . the cord runs down the center of the dash and plugs into the cig light port inside of my center console box located in the corner nearest the passenger. the port is always hot..this I tested with a volt meter and confirmed.
you will need some type of voltage regulation to prevent over charging the battery ....you will need 2 of these
Painless Performance 40030 Painless Performance Electrical System Surge Protectors | Summit Racing
I wired the 2 diodes in series ...they have a red and a black side...you have to wire them either black to black or red to red...doesnt matter which you choose. I terminal crimpted the joint that connects the two diodes and changed the lug terminal on the ends so that they fit the batter terminal tie down bolt. installed across the pos and neg battery terminal. trim the diode wires to give enough slack to connect. I put the finished product inside 2 layers of tube heat shrink. note the pic of the 2 diodes in the below pic. do not wire red/black to red/black or black/red to black/ red..that will drain your battery...must be wired red/black to black/red or black / red to red/black ....this means the diodes has to either point torwards each other or away from each other...not point in the same direction. I cant provide a pic since mine is heat shrink wrapped with heat shrink tube.
if none of the above makes any sense...ask someone with basic electronic knowledge to help. im sure there are dozens of ways of doing this so all comments (praise or attack) are probally ok too. this works for me. good luck.
The solar panel you linked to on Amazon has a voltage regulator already built in. Why would you try to add anything to it? Just curious.
the diagram for the diodes is how to connect…we are not replicating the whole circuit.
the diodes at the link are vehicle voltage regulators rated at 15amps.
so using two cleans up peaks from dc pulse modulated supposed regulators.
if you are comfortable with the built in regulation circuitry you can omit the diodes and save a few bucks.
the autozone panel I have does not have any regulation and can generate up to 21v.
