2022+ F-150 Lightning EV Electric 1/2-ton - Ford's all-electric F-150 has arrived!
2022 Carplay
Old Oct 17, 2022 | 06:44 PM
Deano_1's Avatar
Deano_1
2022 Carplay
Hey everyone,
Is CarPlay supposed to connect wirelessly? Every time I turn on my truck I get a message CarPlay failed to connect and I should connect with a USB.
Thanks,
Old Oct 21, 2022 | 09:57 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@Deano 1 , I don't know the answer to your question, but I would "think" the Lightning would connect wirelessly. My first questions would be...
  • Have you ever been able to connect CarPlay wirelessly, if so, what method did you use? Was it bluetooth or WiFi?
  • Is this means of connection on and have you paired or synced the mobile device with the truck?
  • Does CarPlay work if you connect via USB?
Below is a link to the owners manual posted by another FTE'r. Perhaps the answer with instructions is in there...
Link: 2022 Lightning owners manual.
Old Nov 9, 2022 | 07:45 AM
Deano_1's Avatar
Deano_1
Oddly enough, I can connect to another vehicle with Sync 4 and someone else with the same iPhone can connect to my truck. It even works with a USB cable. For some reason, I just can’t connect wirelessly. Even went to the dealer and they couldn’t figure it out. Tried resetting everything and even disconnected the batteries.
dacflyer
Oct 21, 2020 12:29 PM
mxer0022
6.7L Power Stroke Diesel
Jun 19, 2019 10:50 AM
2cylguy
Jan 11, 2010 11:59 PM
Kansas-Mike
Kansas Chapter
Oct 7, 2006 11:03 PM
