Hard fuel lines
Old Oct 14, 2022 | 11:27 AM
rocketroy's Avatar
rocketroy
Hard fuel lines
I am in the process of changing a few things while I have the bed off my 1990 long box 302 manual transmission 4wd f150..
I have changed all the brake lines , put in the new exhaust.
but I do not know much about these hard plastic what appear to be factory fuel lines
can I just buy rubber fuel hose and clamp the ends …seems a bit magiver to me .
id like to do it right and not have to do it again for another 20 years.
I mean how much pressure is actually in these lines is that why they are hard?
thanks in advance Roy
Old Oct 14, 2022 | 11:45 AM
Prototypemech's Avatar
Prototypemech
The factory plastic fuel lines seem pretty robust. Ford did a good job for securing them to prevent them from getting chaffed or damaged. If they're not leaking, I wouldnt touch them. Yes, you could replace them with rubber EFI rated fuel line of the same inside diameter, but you'll have to resecure them to prevent them from being damaged.
these lines see a maximum of 45psi. I think the earlier 300ci engines run them at 60psi.
Old Oct 14, 2022 | 12:29 PM
My4Fordtrucks's Avatar
My4Fordtrucks
No need to fix something that isn’t broken. Nylon fuel lines don’t rust.
Old Oct 14, 2022 | 02:15 PM
OBS460's Avatar
OBS460
If you want all hard stainless lines checkout inlinetube.com
They used to have an ad in the 4wheeler magazines $99 for a complete set of pre-bent stainless brake lines for some vehicles.
Old Oct 14, 2022 | 04:17 PM
My4Fordtrucks
I have used their SS brake lines on several vehicles. I would not replace the nylon lines unless there is a problem.
Old Oct 14, 2022 | 11:25 PM
rocketroy's Avatar
rocketroy
Thankyou …I will leave them. I was under the truck a lot today and they all seem ..what’s the word …very serviceable.
one of the 90 degree fittings on the end of one line was broken..I’m presuming I can replace that and the little white clips that lock it all together.
thanks
Old Oct 15, 2022 | 07:33 AM
My4Fordtrucks
Yes. There are nylon hose end repair kits. The lines are two different sizes and so are the retaining clips. One hose should have had a white retaining clip and the other clip should be black. Any parts store should have them.
Old Oct 15, 2022 | 11:36 AM
rocketroy's Avatar
rocketroy
Thankyou I appreciate that..
if I figure it out I’ll try to post a picture at some point
Old Oct 15, 2022 | 12:31 PM
My4Fordtrucks
Rear tank on the ‘89
Jesser02EX
Dec 2, 2017 10:51 AM
eutecticpt
Jun 29, 2016 10:01 PM
Diesel 724
Apr 29, 2015 06:10 AM
michbol
Sep 15, 2013 01:13 PM
RA31925
Jun 22, 2011 01:01 PM
