DEF usage
Old Oct 14, 2022 | 11:23 AM
F250NUT's Avatar
F250NUT
DEF usage
I have a 2016 F350 6.7 and tow an 11,000 5th wheel. I always try to maintain the DEF level above the half way level and when I begin a trip I start with a full tank. I think it is 5 gallons. So, I go on a trip down the coast with many hills but nothing too extreme, and after 2,000 miles, I get a message saying I have 500 miles before DEF is empty. So I fill it up and it only takes approx. 2.5 gallons. Does this sound right? I think it should be closer to 4 or 4.5 gallons of almost empty. Anyone else have this issue?
thanks
Old Oct 14, 2022 | 01:46 PM
The Bone's Avatar
The Bone
Ther system is kind of funny. I wait till I got the message 500 miles till limp but the last time I just added a box which should have been fine but the system just reset the millage back to 500 miles. It's the dumbest thing. I finely bought another box to fill it and it took all but about 1/2 gallon. I would just put a box in the truck and when you get to about 100 miles on the counter add the box. Its stupid because the newer 17's have a 7 gallon tank so it will take 2 full boxes when you get the 500 miles. Nothing in our systems seem right. Some guys top it off all the time with no issues. I don't do that because it never takes a whole box when it says under 1/2. I don't even look at the gauge any more because it's not accurate. I hate leaving DEF in the box.
Old Oct 17, 2022 | 04:40 PM
F250NUT's Avatar
F250NUT
Thanks, that makes me feel a little better.
Old Oct 17, 2022 | 05:12 PM
Overkill2's Avatar
Overkill2
If it was really at the 500 mile limit, it would take at least 4 gallons. I have a 16 and have never had an issue with this system. That is goofy. Hopefully it works itself out. I just posted something in my truck thread about this -- I daily drive my truck, no towing, so it uses a lot less than your truck pulling a load.
Maybe a sensor is jammed with crystals so who knows?
Old Oct 17, 2022 | 06:27 PM
senix's Avatar
senix
let it get down to <200 to empty then do a complete fill.
Just take 5 gallons with you if needed or stop by wally world.
System will be less confused if you let it get down and then do complete fills.
Blkdane
Jun 8, 2021 08:58 AM
rbedal
Feb 5, 2021 06:13 AM
RomingnomeTX
Oct 13, 2019 03:52 AM
Drturn90
Aug 14, 2018 02:54 PM
DirtRacer96m
6.7L Power Stroke Diesel
Sep 15, 2017 07:15 PM
