F code rear spring
Old Oct 13, 2022 | 11:02 PM
gnxtc2's Avatar
gnxtc2
4wd Low
F code rear spring
I recently purchased a 7.3 Excursion. I have a set of F code springs sitting in my shop from doing the SD RSK spring swap to my OBS (C code rears/V codes fronts).
My plans for the Ex is just a daily driver. No plans of towing with it either.
I do NOT want to lift the Ex. What is needed to be done with the F codes so I can put them to use.
Looking for a rear sway bar, '08 mirrors and a grille.
Thanks
Billy T.
gnxtc2@aol.com
Old Oct 14, 2022 | 10:13 AM
WE3ZS's Avatar
WE3ZS
So you don’t want to have any lift over stock and you have no towing plans, why are you wanting to swap to the F code springs then? Typically in the past those two items were the driving force behind the various pickup truck rear spring swaps.
Old Oct 14, 2022 | 10:15 AM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
If you are not wanting to change the ride height or load capacity what is the point of changing the rear springs ?
looking at your pics your rear springs look to be fine.
Old Oct 14, 2022 | 10:47 AM
gnxtc2's Avatar
gnxtc2
4wd Low
I thought swapping the springs also gave you a better ride. If not, then my job just got easier.
Billy T.
gnxtc2@aol.com
Old Oct 14, 2022 | 03:14 PM
pirate4x4_camo
FTE Remembers
No,
springs determine payload capacity, set ride height and locate the axle.
your shocks determine how fast the spring can move, this is the key component to ride quality.
tire compliance, a function of sidewall stiffness and psi is another key factor.
Old Oct 14, 2022 | 06:58 PM
gnxtc2's Avatar
gnxtc2
4wd Low
Originally Posted by pirate4x4_camo
No,
True.. springs support the weight of the vehicle and shocks control the action (stored energy) of the springs.
But, a rear SD truck spring is two stage. First stage is light then it hit the second stage then it becomes stiff. No matter what shock you install, if the leaf is too stiff it'll never do its job. Truck will right like a pogo stick. A pickup in the rear is lighter than the Ex that's why a two stage works better.
Just was wondering if I can remove the lower thick leaf (2nd stage) and just use the first stage.
Billy T.
gnxtc2@aol.com
Old Oct 17, 2022 | 08:59 AM
pirate4x4_camo
FTE Remembers
First stage of the F truck rear springs is around 320 lbs/in
Excursion rear springs are 420 lbs/in.
if your Ex feels like it is pogo sticking than you need more compression dampening in the shocks.
Old Oct 18, 2022 | 12:41 PM
Masterz's Avatar
Masterz
In a prior setup, I installed brand-new ($$$) Ford F-code springs on my 05'. I wouldn't recommend it based on your "no lift" interest.
Here's what you get:
  1. Approximately 1.25" of lift (I measured 25.5" after)
  2. The rear of the Ex is heavy enough to make the spring pack sit on the overload spring (you'll need to add a leaf in order to avoid this, so account for more height)
  3. Without the added leaf mentioned above and due to the overload contact, the ride quality was similar if not worse to the factory G-code spring.
Old Oct 18, 2022 | 08:20 PM
pirate4x4_camo
FTE Remembers
The overload spring rate is 670 lbs in.
Old Oct 18, 2022 | 08:56 PM
Masterz's Avatar
Masterz
Old Oct 18, 2022 | 09:06 PM
Masterz's Avatar
Masterz
Moral of the story is, if you aren't willing to lift, then you already have the best spring for comfort and towing that Ford could engineer.
Hopper123
Nov 5, 2021 05:52 AM
UtahGuy
Sep 17, 2021 02:39 PM
pkthomas
Apr 30, 2015 09:14 PM
ccllud
Jul 26, 2013 08:21 AM
acf6
Apr 8, 2013 09:54 PM
