My first engine swap.
Old Oct 12, 2022 | 11:12 AM
Fred Burke's Avatar
Fred Burke
5th Gear
Howdy ford enthusiasts! So I got a 1995 f150 with the 5.0 302 and it blew up this past Friday, I already got a junkyard engine I'm confident in, it's the same year 5.0 302 I was just wondering if y'all have any tips tricks or advice you'd like to share, as I've no idea the intracaces of a engine swap and would appreciate any and all advice.
Many thanks!
Old Oct 12, 2022 | 08:51 PM
Conanski's Avatar
Conanski
Pull the upper intakes off both engines.
Do not remove any engine wiring from your truck, unplug everything on the existing engine and lay the whole harness asside over the drivers side inner fender.
Unless you are 1000% certain that both engines had the same transmission do not use the flexplate that comes with the donor, remove the one from your truck and transfer it to the donor.
If you follow that this should be an easy swap.
Old Nov 26, 2022 | 01:12 AM
Jin's Avatar
Jin
4wd Low
Good luck! I'm hoping to do my first swap soon as well
renchr01
2014+ Transit
Mar 7, 2022 07:47 PM
ss27gogeta
27
Jul 10, 2017 11:47 PM
Jaime74656
Oct 1, 2013 03:56 PM
640 CI Aluminum FORD
2009 - 2014 F150
Sep 5, 2013 10:31 PM
