Starting issue
Old Oct 11, 2022 | 08:43 AM
Gjorgjija's Avatar
Gjorgjija
Starting issue
1994 7.3 idi just change glow plug relay, but i get same issue.
P probably i need to change glow plugs too, but i don't know does will solve the problem.
The problem:
When I start for the first time it starts but imedeatly goes off. After that it crank but without success...
What can be the problem?
Br
Old Oct 11, 2022 | 01:15 PM
Prototypemech's Avatar
Prototypemech
-Prototypemech IDI diagnostic chart-
Cold engine is hard to start and white smoke out the tail pipe= glow plugs dead.
Cold engine is hard to start or starts and stalls out=air intrusion between the low pressure fuel pump and the injectors.
Hot engine is hard to start= injector pump worn out.
Engine stalls while driving=air intrusion problem between the fuel tank and the low pressure fuel pump.
Engine chokes and dies while under-load=fuel restriction.
Old Oct 13, 2022 | 02:41 PM
tjc transport's Avatar
tjc transport
i ain't rite
that is not a glow plug issue, it is air intrusion. you need to change the injector return line caps and o-rings.
what is happening is when the truck is parked engine off, air is getting into the return lines through the old o-rings, and this air lets the fuel in the filter drain back to the fuel tank.
than in the morning you start the engine on a partially empty fuel filter. it will run on the fuel in the injector lines and injector pump, than "run out of fuel" until you re prime it by cranking it over
Old Oct 13, 2022 | 03:06 PM
Gjorgjija's Avatar
Gjorgjija
can you send me photo where to find that part, and what i need to change (and where to buy it)?
thanks
Old Oct 13, 2022 | 03:17 PM
Prototypemech
https://www.ebay.com/itm/7-3L-IDI-Fo...3-a4f004ebae04
follow the steel injector lines from the injection pump to the injectors. They sit on top the injectors, under the fuel line b-nut.
mcphm519
Dec 31, 2019 01:39 PM
roadrunner01
Apr 18, 2011 12:34 PM
Vinford
18
Nov 4, 2007 09:49 AM
Gritz
Dec 18, 2005 02:49 AM
mhalter
Jan 14, 2003 01:24 AM
