6.2L V8 Discuss the 6.2L V8
Broken Coil over bolts
Old Oct 10, 2022 | 03:59 PM
gernsperger's Avatar
gernsperger
2nd Gear
Hi all,
Have'nt seen this problem mentioned, I went to replace my spark plugs on 2012 SuperDuty XLT, 1 st coil over bolt came out OK, 2nd Coilover hold down bolt snapped about 1/2 inch down from the head, coil refused to come off the leftover stud, after forcing it, coil broke at the boss that the bolt goes through. metal sleeve inside this boss was rusted to the bolt, had to Kroil it and work it off the let over bolt stud. the number 3 coilover did the same thing. question is how to get the stud out of the plastic intake manifolt? The metal insert doe not seem to be stout enough to wrench really hard on it. tried PB Blaster and Kroil, nothing. Don't really want to replace the intake manifold.
Any mechanics out there run into this problem? Ideas?
Old Dec 13, 2022 | 08:24 PM
pmasley's Avatar
pmasley
I had this very same problem with mine. Broke 2 off on the driver's side (5 & 8). It took patience. If you have any stud left at all, you may have a shot at getting them out. Soak them down with PB or similar and wait. Also, spray a little down the plug holes. They are notorious for rust too. Go ahead, blow the holes out and take the plugs out and replace. Now you have a choice to make. You can use NKG plugs as they did make the Motorcraft plugs. From what I have heard Motorcraft plugs are now made in China. Last check, NKG plugs are made in West Virginia.
Now to remove the studs. You will need a good pair of vice grips. Ones with teeth and crosshatched. Do not use a cheap pair. It will take some work, some words, and a few other things. Slowly work the stud back and forth. It does protrude through the bottom so it will go both ways. You may only get a 1/16 of a turn or less. Once it breaks loose, don't over do it. Move it out, then back. There is rust on the bottom too that needs to break loose. Constantly spray PB and go SLOW. It took me two hours to get the front one out and three hours for the rear because of the location under the cowl.
Hear is another thought that will save you some bucks. Motorcraft COPS are also made by NKG in West Virginia. Instead of paying $130.00 from Ford, use the NKG. They are a lot cheaper and they spec a little hotter.
Good luck.
thegreatgate
1997 - 2003 F150
Feb 7, 2022 06:32 PM
oldcoupe42
1997 - 2003 F150
Aug 24, 2021 12:10 PM
5speedjoe
Sep 21, 2020 05:43 AM
AFCBrandon
2004 - 2008 F150
Oct 18, 2019 11:05 AM
Johnny Bravo 45
Nov 22, 2013 05:16 PM
