5.4L Engine Coil Pack Bolt Problem
Old Sep 20, 2020 | 06:33 PM
5speedjoe's Avatar
5speedjoe
Trailering
Changing the spark plugs on a 2011 E350 with 5.4L Triton. I got all the plugs and coils changed except for one (#7 cylinder). When I tried to remove the coil bolt, it turned hard for a while, but never backed out. Now it will turn all day, but won’t come out, even while applying upward pressure with a screwdriver under the bolt flange.
If I understand it correctly, there is a brass insert in the (plastic?) part below that the coil bolt threads into. I’m guessing the brass insert broke free so that it turns, but the bolt won’t come out.
FWIW, the engine has 308k miles on it (I’ve had since 294k), and the old plugs looked like they had been in there quite a while. I decided to change all the plugs and coils after it started missing a little when accelerating under load. Otherwise runs great.
Any suggestions or insight?
Old Sep 20, 2020 | 10:02 PM
Philly driver's Avatar
Philly driver
Hi,
You could try to cut the coil where is attached to the bolt and then pull the bolt out. If the bolt is spinning freely what is preventing it to come out is the coil.
Old Sep 21, 2020 | 05:43 AM
JWA's Avatar
JWA
You're right about the brass insert. Some how it has spun in its bore and is not uncommon. Usually this tends to be user error and somewhat easy to do. Cutting the COP might be the only way to remove it but how to correct the intake problem when re-installing the plug and/or COP is another issue
This guy has about the best solution for repairing this problem:
You do need to be VERY careful removing the COP by cutting as its easy to damage the intake. If you use the above method to renew the insert that's a relatively safe operation although Dorman doesn't use the metal inserts to hold the COP's in place---they use a suitable sheet metal screw. This would require a rather short #10 or #12 pan head screw with the intake hole CAREFULLY drilled to secure the COP in place.
IF you're not careful you'll end up replacing the entire intake. If you renew the brass insert use a dab of dielectric grease or anti-seize on the bolt thread and using nothing more than 1/4" drive tools to secure the COP to the intake.
HTH
thegreatgate
1997 - 2003 F150
Feb 7, 2022 06:32 PM
Graham Ryan
Dec 28, 2019 08:30 AM
AFCBrandon
2004 - 2008 F150
Oct 18, 2019 11:05 AM
Johnny Bravo 45
Nov 22, 2013 05:16 PM
mauriciogonzalezfeli
1997 - 2003 F150
Mar 13, 2004 11:25 AM
