Recommendations on e99 injector upgrade
Old Oct 8, 2022 | 03:50 PM
Kintla's Avatar
Kintla
I talked to Bitterroot Diesel the other day. Super helpful guys over there. Trying to decide if I should do stock injectors but upgrade to 7AD/1AE injectors, ( or is all AD injectors a thing?), or do 30% injectors.
If the 30% injectors aren't smokier/louder I guess I'd do those, though I'd choose cleaner/quieter over a small HP bump. I don't want to change turbo, HPOP, or stress the tranny. Some custom tuning would fine.
Any recommendations on best route to go would be appreciated, planning on ordering tomorrow so I get them on Tuesday. Good news is they're only a couple hours away from me.
Old Oct 8, 2022 | 05:33 PM
Wes444's Avatar
Wes444
@ESwift
for AD/30%
As far as all 8 being AD being a thing, what do you think came from the factory?
Old Oct 8, 2022 | 05:54 PM
Kintla's Avatar
Kintla
Originally Posted by Wes444
@ESwift
for AD/30%
I was under the impression that there was a different injector in the number 8 position, the long lead. Bitterroot sells 7 AD and one AE combo pack. AE is the long lead. Not sure what the advantage of that is.
Old Oct 8, 2022 | 06:35 PM
Walleye Hunter's Avatar
Walleye Hunter
My understanding is that it has something to do with allowing the injector at the end of the run to get its full load of fuel but I don't know how it works. 30% is the nozzle size, and I believe that it refers to the size over original. So they would be 30% larger than stock. Injectors can have any size nozzle attached to them but they should be matched to other components on the engine. I have read that 30% nozzles work well with AD injectors. There are a lot of other guys here who know a lot more about it than I do.
Old Oct 8, 2022 | 06:37 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Your selection of an injector depends on your goals for the truck. I wrote a post on October 1st to another FTE'r asking about an injector upgrade.
Instead of pasting it here, you may find some useful information in his thread, which I linked below.
Link: https://www.ford-trucks.com/forums/1...l#post20576537
Old Oct 8, 2022 | 07:45 PM
Dan V's Avatar
Dan V
After 200k miles on 160/30's and all the related upgrades to the engine...some for the 160/30's others because it was the "thing" to do at the time. I long for the days of 7 AD's and and AE, maybe a modded stock turbo.
Old Oct 8, 2022 | 08:12 PM
Kintla's Avatar
Kintla
Originally Posted by Dan V
After 200k miles on 160/30's andcalling all the related upgrades to the engine...some for the 160/30's others because it was the "thing" to do at the time. I long for the days of 7 AD's and and AE, maybe a modded stock turbo.
I was leaning toward the AD injectors and calling it good, keeping it simple. There's that temptation though to keep moding. Truck has 4" exhaust from previous owner, I've added 6637, gauges, tuner, 6.0 cooler, hutch and other stuff.
I don't want smokie *** injectors, I don't want to replace my tranny, which shifts solid right now. You probably just confirmed me on the stock AD set up.
Old Oct 8, 2022 | 08:14 PM
Kintla's Avatar
Kintla
I believe you have an e99 Walleye. Do you have the stock AB injectors in it still?
Old Oct 8, 2022 | 08:48 PM
ESwift's Avatar
ESwift
CNCFAB
I would say 7ad and 1ae
the ad30 have a place for use, they add a little umph in certain situations, feel a bit more like 160/0.
the stock nozzles are, well, stock. They run smooth and tune easy with very few hiccups in the while scheme of things
Old Oct 8, 2022 | 09:07 PM
Kintla's Avatar
Kintla
Would you do custom tunes in going from AB to AD? Or just plop them in and stick with canned tunes?
Old Oct 8, 2022 | 09:14 PM
ESwift's Avatar
ESwift
CNCFAB
should run fine on canned tunes or stock tune.
Old Oct 9, 2022 | 07:31 AM
Walleye Hunter
Yes, my injectors have never been touched and work fine with 5W40 synthetic oil. That's if it ever comes off of the strike it's on. Right now it has some sort of electrical issue and won't start. That being said, I would take a serious look at the AD/AEs with 30% nozzles. From what I've read, the 30%s are as ESwift posted but don't require any goosing of anything else.
Old Oct 9, 2022 | 07:40 AM
ESwift's Avatar
ESwift
CNCFAB
Unless you have a stage 2 cncfab hpop go with stock nozzles
I highly recommend just leaving them stock nozzles
Old Oct 9, 2022 | 09:36 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Here's a good post about the long lead injector. It's rare that a customer wants 8 AD injectors.
https://www.ford-trucks.com/forums/1...l#post20581212
Old Oct 9, 2022 | 10:44 AM
Kintla's Avatar
Kintla
Bummer about the no start, electrical problems are no fun. Best of luck getting that sorted.
