slide problem
Old Oct 15, 2022 | 02:54 PM
  #76
RV_Tech's Avatar
RV_Tech
Forgot to say, make certain those wire nuts are tight behind your switches. Your hot connection is one of those connections to the switches.
Old Oct 15, 2022 | 02:59 PM
  #77
senix's Avatar
senix
those connections (wire nuts) are secure. I removed them and had a look.
So with all of them (wire nuts and the wires) having a good connection with the result being the red light still present with each switch......the hot wire going into the fuse box might need to be relocated to another terminal?
Or as you indicated, maybe the wire going to the fuse is loose. I did not tug on it or otherwise mess with it, Suppose that is a next step.
Old Oct 15, 2022 | 03:09 PM
  #78
RV_Tech's Avatar
RV_Tech
Since you have a 30 amp fuse for the slide I am assuming you have a heavier lead for that fuse. If you want to do something quick just switch the lead the fuse is feeding for the slide to another terminal and make sure you have at less a 20 amp fuse in that terminal and try running your smallest slide.
you are doing well!
Old Oct 15, 2022 | 03:11 PM
  #79
senix's Avatar
senix
great idea. So that box, I know nothing of them, is there a way to open it up?
Old Oct 15, 2022 | 03:20 PM
  #80
senix's Avatar
senix
Of note also, the owners manual only indicates the 30 amp at the breaker box.
Also it looks like you remove the top of the breaker box for access looking at my previous pictures?
Old Oct 15, 2022 | 03:26 PM
  #81
RV_Tech's Avatar
RV_Tech
Very easy to access. Just a screw driver and big box cover comes off. Make sure your shoreline is not plugged in as breaker connections will be bare also . Take your time. I don’t have a good pic of your box or I could be more specific.
Old Oct 15, 2022 | 03:29 PM
  #82
senix's Avatar
senix
10-4, good enough for now. Will check all this tomorrow and hope the wire is loose or just a bad connection.
Old Oct 15, 2022 | 03:35 PM
  #83
RV_Tech's Avatar
RV_Tech
Fingers crossed😃
Old Oct 16, 2022 | 12:08 PM
  #84
senix's Avatar
senix
Success, I have power! did I mention I hate electrical?
I first determined the wiring I had though was the circuit was in fact the wire. Testing with the cover off reveals no power.
fished the wire from under the box and out of the hole from the switch panel.
Hooking the wire directly to another circuit and I now have power to all slides. I tried a 20 amp and then I put the original 30 amp in the slot and it also works.
So a bad circuit in the power distribution box is it. So can I just use the new circuit or is it recommended to replace the box?
back of panel
wiring before moving the circuit
power at the new circuit
wiring hooked before applying power
Old Oct 16, 2022 | 12:15 PM
  #85
RV_Tech's Avatar
RV_Tech
First of all congrats! You did it! Yes, just use a different circuit. Make sure you have large enough wire in the new circuit. You can just move wires around. The problem you had is a rarity. I have almost never run into it so that made diagnosis a greater challenge.
Old Oct 16, 2022 | 12:19 PM
  #86
senix's Avatar
senix
do you recommend using the old 30 amp fuse or just a 20 for the circuit?
Old Oct 16, 2022 | 12:36 PM
  #87
RV_Tech's Avatar
RV_Tech
use the 30 amp. Wouldn’t go smaller give startup motor amp draw.
Old Oct 16, 2022 | 12:40 PM
  #88
senix's Avatar
senix
Thanks good enough
Old Oct 17, 2022 | 07:58 AM
  #89
kshoop1958's Avatar
kshoop1958
Congratulations Scott! I've been following your progress because I know just enough about electrics to be dangerous, and figured I might learn something. And what I learned is that when I'm near near Bristol with an RV problem, I'm calling RV_Tech. What a gentleman you are sir!
Old Oct 17, 2022 | 09:29 AM
  #90
senix's Avatar
senix
X 2, the key here was his expertise in knowing the switches I had.
Then I knew there were no other relays to worry about.
