Ghost Squeaking in PULLIES
Old Oct 7, 2022 | 02:21 PM
Jc009's Avatar
Jc009
1st Gear
Have 08 5.4l 3v.
Pullies sqeaking. I have replaced all the 3 idler pullies, power steering pump, tensoner, water pump and has a new belt.
Does not squeak with the belt off.
I can't seam to locate the issue. Tried isolating by spraying lube on each pulley and seams to go away for short while.
Ac and heater doesn't seam to affect it.
Thank you.
Old Oct 7, 2022 | 09:59 PM
steve(ill)'s Avatar
steve(ill)
normally if you shoot soapy water on the belt... and the SQUEEK goes away for a minute... its the BELT.. It may be slipping on the pulleys.. Sometimes cleaning the pulleys will fix that ( oil on pulley)... sometimes you need a new BELT.
CharlieV5
Nov 5, 2022 10:05 AM
AlsRyd66
Oct 13, 2019 08:54 AM
AlsRyd66
halfbolt
Dec 3, 2007 11:58 PM
crash104936221
May 28, 2006 10:22 AM
