Sponsored by: Real Truck
Squeaky Serpentine (Under Load)
Old Sep 11, 2022 | 08:48 PM
CharlieV5's Avatar
CharlieV5
4wd Low
Hello, New User here.
I have an old 2008 F250 with 5.4L
Used to be a State of TN Road Maintenance Truck, Flashing Lights, etc.
A few months back it developed a hell of a squeak, thought it was going to pop my
serpentine belt, so I parked it, just got around to working on it the last few weeks.
Replaced Tensioner and Idler Pulley, no change.
Replaced Water Pump & Pulley, no change.
Replaced Serpentine with pretty good AutoZone belt, no change.
Took it in to a shop, they said A/C Clutch
Replaced A/C Clutch Pulley bearing, Gap'd the clutch, still.... no change.
Issue happens usually above 1200-1500 RPMs
Happens with A/C On or Off
Happens more going up hill and with higher RPMs.
If I keep the RPMs as low as I can, I can get around the neighborhood,
to the store, and hear minimal squeaking.
I took the alternator off and had it tested at auto zone, they said it was good,
and it did NOT squeak at all when they tested it.
This issue is driving me out of my mind. I guess I could replace the Tensioner ANDIdler Pulley --again-- but I really don't want to.
Again.... A/C works fine. Nice and Cold.
Would the Compressor Squeak with higher RPMs, and be a separate problem even after replacing A/C Clutch bearing, All while A/C works just fine??
Thanks very much for any help
Charlie
Old Sep 12, 2022 | 09:06 AM
WWR's Avatar
WWR
We're positive it's the belt? Can you remove the belt and briefly take it up to the rpm range where the noise occurs?
You should have 2 idlers in addition to the tensioner pulley -- you replaced all three?
Old Sep 12, 2022 | 09:32 AM
redford's Avatar
redford
FTE Leadership Emeritus
Pull your belt off and rotate all pulleys by hand. They should all turn smoothly with possibly some resistance. If you find one that feels rough or gritty you found your issue.
Don't forget about your alternator, water pump and power steering pump.
Old Sep 12, 2022 | 10:29 AM
CharlieV5's Avatar
CharlieV5
4wd Low
Thanks, I'm heading outside to take a look in a little bit, will let you know....
Old Sep 12, 2022 | 10:31 AM
CharlieV5's Avatar
CharlieV5
4wd Low
I'll check for another idler. Never even though of that.
(Have never had a truck large enough to have 2 Idlers....)
Will also try removing belt, and raising RPM for10-20 secs.
Will let you know.
Old Sep 12, 2022 | 10:52 AM
WWR's Avatar
WWR
Will let you know.
There's an idler left and right of the alt.
Team TFI wanted to make the belt routing as convoluted as possible. They did a good job.
If you have steel idlers you can also just press in new bearings:
https://www.ford-trucks.com/forums/1...l#post19297785
Old Sep 12, 2022 | 11:05 AM
WWR's Avatar
WWR
Also OP this vid is great. He talks about chatty pulleys and anything pertaining to the engine will pertain to your SuperDuty:
Old Sep 12, 2022 | 01:17 PM
CharlieV5's Avatar
CharlieV5
4wd Low
Hi,
I checked the diagrams I could find (as I don't have a Haynes manual yet), and the 5.4l
with 2 Idlers looks different than mine. When leaning over radiator, I just have the
one idler above the tensioner & Compressor, not the one on the right as is shown in
some super duty serpentine diagrams. I did try taking the belt off, and starting engine
for 15 secs, seems like squeak is still there!!! Is it possible the cranks harmonic balancer?
Charlie
Old Sep 12, 2022 | 01:46 PM
WWR's Avatar
WWR
If you're truly still getting the squeak with no belt it's obviously not the belt drive....
Scary version is something in the timing set. I would think a chain eating thru the timing cover would be more of a grinding sound.
Has anyone experienced a squeak from the timing set? If you had a DIS Cologne motor I'd say camshaft synchronizer but that doesn't apply to the Tritons...
How many miles on the vehicle?
Old Sep 12, 2022 | 01:48 PM
bajaphile's Avatar
bajaphile
Are you able to recreate it while in the driveway while in park while you open the throttle? (Or have someone press the accelerator pedal?)
I've always used a hose or spray bottle set on jet and applied water on each pulley until the squeak goes away. It usually will point to the culprit. Not sure how easy it will be to get in there on the Ford with the fan and shroud there limiting your access though. How's your power steering fluid level and fluid quality looking?
Old Sep 12, 2022 | 01:57 PM
WWR's Avatar
WWR
His videography when attempting to show the problem is pretty bad but this guy apparently had a wobbling balancer causing your symptoms, so perhaps your inquiry about the harmonic balancer was correct:
Old Sep 12, 2022 | 09:06 PM
CharlieV5's Avatar
CharlieV5
4wd Low
Because of a test I did earlier today, I found out it is squeaking even with the Serpentine Belt off.
I tried it for 15-20 seconds (with engine cold), and at higher RPMs it is squeaking.
Only thing turning is the crank pulley at this point. (No belt)
Is it possible it can be a Harmonic Balancer issue? or would it most likely be
something inside? It is 1/4 qt low on oil, but I wouldn't think that's the issue.
Old Sep 13, 2022 | 10:35 AM
redford's Avatar
redford
Wow, squeaking with no belt?
Could be timing chains, cam phasers, or maybe the VVT solenoid. Hard to say. You might need a stethoscope to pinpoint.
Old Sep 13, 2022 | 11:38 AM
WWR's Avatar
WWR
I feel like you should probably read Post #11
Post #11 might cause you to think there's at least a possibility a harmonic balancer is indeed causing his issue, as he suggested and even I ignored that thought until watching the vid in Post #11.
It also makes sense he might only get his squeak "under load" as the rubber in the balancer might struggle more to maintain shape under load and/or at higher RPM's
I am NOT saying this definitely is his problem, but I AM saying this is a check he can do visually in ~10 seconds. Fast and free: the best kind of troubleshooting. And way less scary or expensive than timing set issues.
Old Sep 14, 2022 | 10:09 AM
CharlieV5's Avatar
CharlieV5
4wd Low
WWR,
Just saw your recent msg. I just picked up a Harmonic Balancer from O'Reilly, and have an OEM brand HB puller coming from Amazon tomorrow. Not sure if the noise that I hear, even with the belt off, is coming from the HB or possibly something that the failed HB has damaged, or...... something that was damaged causing HB to fail. I just hope that this HB fixes the issue.
